Reading: Measure Flow rate using Level Sensors
Inst Tools > Blog > Flow Measurement > Measure Flow rate using Level Sensors
Level sensors are capable of measuring more than just level. Flow rate measurement in an open channel can be accomplished using weirs and flumes.
Last updated: November 1, 2023 5:51 am
Flow Measurement
2 Min Read
Level sensors are capable of measuring more than just level. Flow rate measurement in an open channel, such as a stream, irrigation canal, or unpressurized sewerage pipe, can be accomplished using hydraulic structures known as weirs and flumes.
These measure flow rates using the same technologies often applied to tank-level measurements, such as bubblers, radar, and ultrasonic level transmitters.
Level Sensors Measure Flow
Both weirs and flumes function by constricting the flow of the channel and measuring how the fluid level is affected.
Their physical characteristics, and therefore their effect on fluid flow, are known variables, so equipment that measures the level upstream from the structure can use a series of mathematical equations to determine the flow rate.
Weir Flow Meter Principle
Weirs function very similarly to dams in that they span the length of the channel and constrict the flow.
There are many styles of weirs, each meant for a different application, but they all allow fluid to escape through an opening and continue downstream. The fluid level is measured upstream from the weir.
Flumes Flow Meter Principle
Flumes, on the other hand, typically consist of three sections: a constricting end, a throat, and an expanding end. The flume is partially submerged in the channel. The throat constricts the flow and the fluid level is measured at the constricting end.
  • Flow Transmitters Questions
  • Velocity Flow Meter Principle
  • Flow Control Loop Controller
  • DP Flow Transmitter Measure
  • Float Switch Working Principle
Coriolis Flowmeter Advantages and Limitations
What is a Torbar? – Averaging Pitot Tubes
Annubar Flow Meter – Principle, Advantages, Disadvantages
Pressure based Flow Meters
Flow Meter Calibration
Basics of Venturi Flow Meter
How to Read Circular Chart Recorder for Flow Measurement?
What is a Variable Area Flow Meter?
Configure the Instruments in Flow Control Loop
Rotameter Working Principle and Animation
What is a Ultrasonic Flow Meter?
Continuous Flow Measurement
Flow Transmitter Output Current Calculation
Calculate Flow Transmitter Output Current
Weigh feeders Principle
What is a Weigh Feeder?
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
Coriolis mass flowmeter Density Measurement
How Coriolis Mass Flow Meter Measure Density?
Orifice plate with vent and drain holes
Basics of Orifice Plates
Coriolis flow meter sensor coils
Coriolis Flow Meter Construction
Oscillating Piston Flow Meters Principle Animation
Thermal Dispersion Flow Switch Working Principle
Process Control Fundamentals
Alarm Management Practices
Control Room Alarm Management Practices
As-Interface Protocol Overview
AS-interface and DeviceNet Communication
Power Systems MCQ Series 21
Schneider Electric Modicon M340 PAC
PLC vs PAC – Understanding the Key Differences and Similarities
Motor Operation for Local Control Panel
Motor Operation from Local Control Panel – Video
HIPPS Operating Philosophy
Understanding High Integrity Pressure Protection Systems (HIPPS)
Arc Fault Breaker (AFB) Electrical Problem Solved
