Reading: Level Control Valve with Horizontal Float
Inst Tools > Blog > Control Valves > Level Control Valve with Horizontal Float
In a level control with horizontal float consists of the main valve, needle valve, pilot float, and float with an arm.
Last updated: September 28, 2022 2:34 pm
R Jagan Mohan Rao
Control Valves
3 Min Read
In a level control with horizontal float arrangement, the whole system consists of the main valve, needle valve, pilot float, float with an arm in the figure below.
Level Control Valve with Horizontal FloatAdjustmentApplications
Horizontal float level control valves allow the water level of the tank or reservoirs to be controlled automatically at an affordable cost with a simple mechanism.
Image Courtesy: Bermad
The main valve automatically opens, closes, or modulate as with level requirement helps to control the water level of tanks of reservoirs.
The Horizontal float and level control valve can be mounted in close proximity to the tank. Else the level control valve can be mounted down below the tank or at an accessible location on the floor as the figure is shown below.
Level Control Valve Mounted on the Tank
Image Courtesy: TVN Valve & Piping Company
As with the rise of the tank water level, the float closes the pilot valve. Hence back pressure is developed, water accumulates in the upper actuator chamber, and the actuator is pressurized to close the main valve.
When the water level falls below the set level of horizontal float, the pilot valve gets open. Water flows through the main valve.
The sequence of operations will be repeated on its own without the intervention of external control mechanism.
Adjustment
According to the maximum water level, mount the float that is a part of the system. Fix a connection hose between the valve and the pilot float.
When the water level falls below the adjustable level, the valve opens to fill the tank.
Adjust the opening and closing speed of the main valve according to your system with a needle valve on the valve unit. Full open adjustment of needle valve allows rapid fill-up of the valve chamber, and less adjustment makes slow fill-up.
As soon as it level float reaches the set level, the pilot float is closed also the main valve, and the water level remains constant.
Applications
  • Household overhead tank.
  • Various industrial uses, for example, fire water tank level control.
Reference: BERMARD waterworks
  • Advantages of Shutdown Valve
  • Control Valve Commissioning
  • Maintenance of Control Valves
  • Basics of Control Valve Sizing
  • Valve Relation between Cv and Kv
Deluge Valve Operation
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Valve Interlock
How do you do control valve sizing in Layman’s terms?
Pneumatic Control Valve Actuators
Safety Relief Valve Questions & Answers
Control Valve Stroke Test Procedure
Inherent vs Installed Control Valve Flow Characteristics
Control Valve in Nutshell – Valve Design and Selection Factors
Identify Valve Parts Quiz with Answers
Solenoid Valves Types & Functions
Control Valves Pre-Commissioning Checklist
What is a Pneumatic Cylinder?
What is Stop Check valve ?
Butterfly check valves
What is Butterfly Check Valve ?
Quick Exhaust Valve (QEV)
Quick Exhaust and Air Operated Valves in Instrumentation Circuit
Control Valve pressure recovery
What is Control Valve Flashing ?
Facts of Control Valves
Facts About Control Valves
Difference between Globe Valve and Gate Valve
Difference between Globe Valve and Gate Valve ?
Purpose of Float Valve
What is a Float Control Valve? Types, Advantages, Disadvantages
Solenoid-Valve-Manual-Reset-function
Solenoid Valve with Manual Reset Working Principle
Free Online Control Valves Course
Free Control Valves Course
Paddlewheel flowmeter principle
What is a Paddle Wheel Flow Meter?
Boiler Three Element Controller Philosophy
Snubber Circuits
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
AC Induction Motor Construction
Basics of AC Induction Motors
Chlorine Cylinders
Chlorine Gas Hazards
Measure Capacitance using Multimeter
How to Measure capacitance using Multimeter
Lamp Counter Logic
Function Block (FB) for Motor Control Logic
Practical Control Systems Questions & Answers - 2
Practical Process Control System Questions & Answers – 2
