Reading: Jump Instruction in Siemens Tia Portal
Inst Tools > Blog > PLC Tutorials > Jump Instruction in Siemens Tia Portal
The jump instruction is used to skip part of the PLC logic or rungs during the program run in the Siemens Tia Portal.
Last updated: March 4, 2021 11:12 am
3 Min Read
In this article, I will explain to you about the use of the JUMP instruction using Siemens TIA PORTAL
The jump instruction is used to skip part of the logic or rungs during the program run.
Now, why JUMP instruction? You may ask. The simple answer is to reduce scan time (one of the advantages).
To jump unnecessary logic which we don’t want to execute while program in run mode can reduce the amount of scan time.
Also Read: JUMP Example
Let’s dig deeper to understand JUMP instruction with the help of an example.
Open TIA PORTAL. Enter into a programming environment.
I have added little program in the second network as you can see in the below window.
Now, I want to skip that second network. To do that I have added JUMP instruction in the first network.
In the third network, I added a label, which indicates the location of the jump.
To use JUMP instruction, you have to define it. You can define any name but always remember to use the same name as the label.
Here in our case, I have used the letter “D” in both JUMP and label instruction.
You can see in the below window, execution of the JUMP instruction.
When you turn ON input in the network 1, JUMP instruction will execute which then goes to the label and execute the logic. (in our case it goes to the rung where the label is used)
You can see that when JUMP instruction is active, the second network is disabled.
Jump in PLC
As you can see in the below window that if I try to turn ON the input in the second network, the output won’t get energized.
As soon as you switched off input in the first network, the second network will be activated again.
Conditional Jump instruction
Author: Suhel Patel
  • Forcing and Modifying PLC Logic
  • Check Block Consistency Tools
  • PLC Program using Pushbuttons
  • Microprocessor Programming
  • What is Profinet in Siemens PLC?
Mitsubishi PLC Programming Tutorials
How to Delay a Sensor Signal in PLC?
Door Lock with Delay PLC Exercise Problems
PLC Programmer Salary and Future Career Scope
Difference between Timer and Counter – PLC Basics
What is an Instruction List? – PLC Programming
What are FIFO and LIFO Sequences in PLC?
Sorting & Distribution Line PLC Programming – Advanced Logic
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
PLC Programming for Garden Sprinkler System
InTouch SCADA Login Password Security
What are High-Speed Counters and Fast Counters in PLC?
PLC Timer Instructions
PLC Program for Positive edge pulse output for one scan cycle
PLC Program for Positive Edge Pulse Output for One Scan Cycle
PLC Program for Fish Feeding System
PLC Timer Application in Security Camera Recording
Count the Number of Bottles
Count the Number of Bottles in Packaging Carton PLC Logic
Mixing Tank Relay Circuit
PLC Program for Mixing Tank
Allen Bradley PLC Emulator
How to Work with Allen Bradley RsLogix Emulator?
Communicate with Excel from Intouch SCADA
How to Communicate with Excel from Intouch SCADA?
DeviceNet
What is DeviceNet?
List of 100 Questions Related to Distributed Control Systems (DCS)
List of 100 Distributed Control Systems Questions (DCS)
PLC Program for Water Level Control
PLC Program for Water Level Control Logic
PLC Program to Drain Same Products from Two Tanks
PLC Program for Automatic Door Control System
PLC Automatic Door Control System – Programming Example
Burst Transformers Root Cause Analysis
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
pcb slip rings
Slip Rings in Robotics – Types, Applications, Advantages
Gas Holder Level Measurement
Measurements in Air and Fuel Circuit in Power Plant
