Reading: Create Logic with InTouch Scada using Scripting
Inst Tools > Blog > PLC Tutorials > Create Logic with InTouch Scada using Scripting
Last updated: March 4, 2021 12:21 pm
3 Min Read
Learn how to create logic using Wonderware InTouch SCADA software using the scripting language.
InTouch Scada Scripting
There are six types of logic gates. We can create a voting system using them and also, we can create PLC programming logic using a combination of them.
Here I will create a script to turn ON lamp by using all logic gates. To do that so, open InTouch application.
Step 1:
Create a new project and enter an animation environment as shown in the below window.
InTouch Project
Step 2:
Go to the wizard as shown in the below window. And add a switch and lights. As we are using six logic gates we will add twelve switches and six lamps.
Wizard Selection in InTouch Scada
Step 3:
Add all the objects as shown in the below window. Give tag name as per text. Do read my article on it.
Assign Tag names in InTouch scada
Step 4:
Right-click on the display as shown in the below window. Select “windows script”.
Windows Script in InTouch Scada
Step 5:
The following scripting window will open. Select condition type. In “on a show” it will always remain starting condition.
In “while showing” option, we have to write a script to operate switch and lamp. Also, select every and enter some time in it.
InTouch HMI Scripting
Step 6:
Here, I have added an initial condition as shown below. It always remains zero.
SCADA Scripts
Step 7:
In “while showing” I have written condition to turn OFF and ON gate, based on the type of logic gate and lamp will turn ON accordingly.
intouch show window script
Step 8:
After writing down condition click on “validate” than “convert” and then hit “ok”.
To test the logic click on “runtime” located on the top right of the below.
InTouch SCADA Condition script Tutorial for Beginners
Step 9:
When switches are OFF NAND, NOR AND XNOR gates will remain ON.
Switch Simulation in InTouch Scada
Step 10:
When S1 is ON then OR, NAND, and XOR gate’s lamp will turn ON.
Logic Gates in InTouch Scada
Step 11:
When S2 is ON then OR, NAND, and XOR gate’s lamp will turn ON.
InTouch SCADA scripting language
Step 12:
When both S1 and S2 are ON then the lamp of AND, OR and XNOR will turn ON.
Creating Logic in Intouch Using Scripting
Author: Suhel Patel
  • Quiz Questions on Motors
  • Modifying PLC Programs
  • Field instrument to Control Room
  • What is SCADA System?
  • Siemens Profinet Configuration
How to Write and Read a Program for Mitsubishi FX3U PLC?
How CPU Execute Program in Siemens PLC?
What is Ladder Diagram Programming ?
PLC Ladder Logic Design: Control 3 Motors with Toggle Switch
PLC Program Example on Multiple LEDs using Set Coil
PLC Interlock Logic with First Input Priority
PLC based Drink Dispenser System
How to import GSD files into the TIA Portal? – Siemens PLC
Remote Factory Acceptance Test
Tia Portal – Optimized and Standard Data Block Access
PLC Data Logging and Transmission
Moving Data between PLCs – Siemens Basics – TSEND TRCV
PLC Programming for Pumping and Draining System
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
Siemens Process Mode
Test and Process Modes in Siemens PLC
PLC Temperature Control using Pulse Width Modulation
PLC Temperature Control using Pulse Width Modulation (PWM)
Step-by-step import export in FactoryTalk View
FactoryTalk View Studio – Import and Export Tutorial
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Flow Control Valves
Difference Between a Flow Control & a Needle Valve
4-20mA Loop Power Supply Questions
RSLogix5000 PLC Program Backup procedure
Hazard Identification and Risk Assessment
Interferometer Principle
RTD Calculator Software
Direct Lift Diaphragm Normally Open Solenoid Valve
Types of Pilot Operated Diaphragm Solenoid Valve Principle
Fire Extinguisher Operation
Basics of Fire Extinguisher
