Reading: How to Interchange ON Delay Timer and OFF Delay Timer in a PLC
Inst Tools > Blog > PLC Tutorials > How to Interchange ON Delay Timer and OFF Delay Timer in a PLC
Last updated: March 4, 2021 3:56 pm
2 Comments
Timer functions are most important in PLC Programming. Logics play the important role in PLC Programming.
ON Delay Timer and OFF Delay TimerPLC Timer FunctionsON DELAY TIMER :OFF DELAY TIMER :List of Inputs and OutputsPLC Program for ON Delay and OFF Delay TimersLadder Logic DescriptionConclusion
According to PLC programmer’s skills, logic will get different in application. In this program, we are going to interchange the function of On Delay Timer and Off Delay timer. AB RSLogix 500 is used to implement the concepts.
PLC Timer Functions
ON DELAY TIMER :
In Layman Statement, Delaying the turning “ON” of the output is On Delay Timer.
Example :
See the image below; if you turn on Input, after 5 sec output will get turn on. It will not turn on immediately.
PLC ON DELAY TIMER FUNCTION
In AB PLC, ON Delay Timer is having 6 parameters.
They are
  • Enable Bit (EN): It will turn on when timer is on
  • Done Bit (DN): It will turn on once the timer accumulator value reaches preset value
  • Timer Timing bit (TT) : This bits enable when timer accumulator value is running
  • Preset (PRE): Integer value to set how long timer needs to run or limit starting from zero.
  • Accumulator (ACC): Running value of the timer
  • Time Base : You have options to chose timer base, Sec, cent sec, Mille sec.
OFF DELAY TIMER :
In Layman Statement, Delaying the turning “OFF” of the output is Off Delay Timer.
Example:
See the image below; if you turn on Input, output will turn ON immediately, when you turn OFF the input, It will take 5 sec to turn OFF the output. It will not turn OFF immediately.
PLC OFF DELAY TIMER FUNCTION
In AB PLC, OFF Delay Timer is having 6 parameters.
They are
  • Done Bit (DN): It will turn on once the timer is On and remains ON until timer accumulator value reaches preset value
  • Time Base: You have options to choose timer base, Sec, cent sec, Millie sec.
PLC Timer Logic Inputs Outputs
ON DELAY TIMER AS OFF DELAY TIMER
OFF DELAY TIMER AS ON DELAY TIMER
ON DELAY TIMER AS OFF DELAY TIMER :
1. Rung 0000 :-
Latching is done using output coil to stay ON even Input is turned off. Normally closed timer done bit is used to turn off the output once timer accumulator value reach preset and that make TON to act as TOFF.
2. Rung 0001 :-
since the Start Input is used as normally closed input, Output Coil is attached as interlocking, so that it won’t turn on timer at the beginning of the program.
OFF DELAY TIMER AS ON DELAY TIMER :
3. Rung 0003 :-
Input 2 turned to turn on timer, Memory coil is used to trigger the timer to start count and to make TOFF to act as TON.
Conclusion
The above used timer concept is used to under the function of timer working. It may or may not used in real time application.
Author : Hema Deepan
MCQ on PLC Test
Compare PLC and DCS
What is Relay Logic ?
PLC Maintenance List
Boiler PLC Start-up
Process Interlocks and Trips
Free SCADA Training Course
PLC Practice Questions
How to Work with Allen Bradley RsLogix Emulator?
Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
PLC Analog Input Card Resolution Effects on Accuracy
2 Comments
  • SNEHIL SHUKLA says:
    March 31, 2022 at 9:31 pm
    There are two lamp on pressing the start push button the first lamp should go on when the start push button is press again the first lamp should go off and the second lamp should go on if any of the lamp is on for more than 15 second they both the lamp will interchange their status ? Please solve this problem ?
    March 31, 2022 at 9:32 pm
    How will we be interchange their status?
Site Commissioning Steps for PLC Programmers
XG5000 Example of Simple Conveyor Control PLC Program
Configuration of InTouch Scada Trends
Smart Automation Solutions: PLC Logic for Stairway Lighting
How to Simplify PLC Coding Using Karnaugh Maps?
Pause the Timer PLC Ladder Logic
PLC Program to Control Motor Speed using VFD Drive
Motor Speed Control using VFD and PLC Programming
What is an RTU - Remote Terminal Unit
What is an RTU? – Remote Terminal Unit
Download Free Robotics Software
Step by Step Guidelines to Download Free Robotics Software
PLC Compressor Control Ladder Logic
Free Download PLC Book
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
Shift Bit Register in PLC
Two Hand Control Logic
Two Hand Control Logic using PLC
Electric Motor Actuator Parts
GC sample loop
Chromatograph Sample Valves
Classic Control Circuits
Add an alarm display to the graphics.
How to Configure an Alarm in InTouch SCADA?
Open Tank Interface Level measurement principle
Open Tank Interface Level Measurement
Thermocouple cold junction compensation
Why Thermocouple Reference Junction Compensation Required ?
Basics of Trips, Interlocks, Permissives & Sequences
Electron Spectroscopy for Chemical Analysis
