Electrical engineering root cause analysis (RCA) related to industrial plant Illumination external corrosion.
Article Type: | Root Cause Analysis (RCA) |
Category: | Electrical |
Equipment Type: | Plant illumination |
Author: | S. Raghava Chari |
Industrial Plant illumination Problem
The light fittings and street light poles too were victims of external corrosion and demanded excessive maintenance efforts. Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â
Solution
The below-given steps eliminated the entire problems:
- Substitute the metallic lighting fixtures with FRP fixtures assembled with threads greased SS screws
- Substitute energy wasting and short lives incandescent lamps with energy saving long life mercury vapor lamps, sodium vapor lamps etc.
- PVC chain-suspend incandescent lamps – inevitable in vibrating machines areas. The pipe suspensions transmit the structure shakes to the lamps; but chains do not. Hence, the lamps would last longer
Replace corrosion end of lives steel poles with concrete poles. Most plants’ crew can develop designs and make these. Initial costs are lower and no periodic painting saves still more.
Author: S. Raghava Chari
- HT motors Corrosion
- Poor Power Factor Problem
- HT Motor Direction of Rotation
- Inability to Test Repaired HT Motors
- General Corrosion of Electrical Motors
