Reading: How to Write a Program in Ecostruxure Machine Expert HVAC Software?
Inst Tools > Blog > Control Systems > How to Write a Program in Ecostruxure Machine Expert HVAC Software?
In this post, we will learn how to write a program in Schneider Electric EcoStruxure Machine Expert HVAC programming software.
Last updated: November 22, 2022 12:42 pm
Control Systems
Ecostruxure Machine Expert HVAC is software used in the Schneider Electric platform. It is used to program two ranges of PLCs – TM171 and TM172. This software is specifically designed for HVAC and pumping applications.
Ecostruxure Machine Expert has specially designed libraries and function blocks for catering to such types of applications; which makes coding easy for the programmer. In this post, we will see simply how to write a program with this software. We will use TM172 as a reference PLC for this post.
Open the software and write a name for the project as shown below. I have written the Test as shown.
Select the directory where you want to save this program. Choose the PLC that you are using. Then, click Create, and thus, your backup will now be created.
The following window will appear as shown in the figure. As you can see, there are four tabs in it – configuration, programming, display, and commissioning.
We will write a basic program here to first understand the concept. The configuration tab is used to assign IO variables and variables which are to be mapped outside the PLC (like for HMI or SCADA).
The programming tab is used to write the program. The display tab is used to design in-built HMI screens (this option comes for M172 PLCs only). The commissioning tab is used to configure the hardware of PLC (like IO, IP addresses, etc).
How to Write a Program in HVAC Software
First, we will take 2 digital inputs, 2 digital outputs, 2 analog inputs, and 2 analog outputs. Refer to the screen below. From this, you can understand that you to define the variables at the points which are being used for your wiring. This will configure your IO variables.
Schneider Electric HVAC
Next, we will define the variables which will be used in HMI. For that, there are two types – EEPROM and Status.
EEPROM variables are retentive ones and are used as write-only variables. So, they can be termed as settings parameters.
HVAC Machine Expert
Note that you cannot write any value from the program in these variables. They can be written only through HMI or other outside graphic display.
Status variables are used for showing some status and they can be used as both read and write variables. Refer to the below images. Two variables have been created in each of them.
Status Variables in HVAC Software
Now, we will write a program with these variables. Refer to the below figure for reference. Right-click the project name, click add and then click new program.
HVAC control solution
You will be prompted to select the language; choose the one which you want. I have chosen LD (ladder language) as the one.
Name the program section according to you and assign this section to the timed task. On clicking ok, the section will now be added to your program.
HVAC New Program
Design the program according to your requirement, as shown in the figure. One more thing to be added is the additional variable definition facility.
You have two options – local and global. As shown in the figure, the TEMP_OK variable is defined as a local one.
So, you can use this variable in this section only. If you had defined it in the global section, then the variable could be used anywhere in the program.
EcoStruxure Machine Expert - HVAC - Programming Software
Now, we will configure the commissioning tab.  In this, we will configure the analog inputs by selecting their type.
As shown in the below figure, I have configured AI1 and AI2 as 4-20 mA; because in the earlier section, as you can see, I had used only two of them.
HVAC and Building Automation Software
Thus, your basic program is now ready. You can now use it to download it in the PLC.
In this way, we understand how to write a program in Ecostruxure Machine Expert HVAC.
  • Modbus Function Codes
  • Motor Classic Control Circuits
  • Features of Scada in IoT System
  • Cyber Security MCQ Questions
  • Add On Instruction Programming
Turbine-Compressor System Architecture
Evaluating Industrial Automation Projects Return on investment (ROI)
List of 100 Distributed Control Systems Questions (DCS)
  • ayham says:
    June 13, 2023 at 12:41 pm
    Some photos above doesn’t appear, please update it
Electrical Earthing Calculations
Tuning a Liquid Level Process Control Loop
Basics of Loop Checks
What is a Annunciator Panel?
Proportional-only Offset
Boiler Three Element Controller Philosophy
ESD System Insights: Signals for Emergency Valve Shutdown Explained
What is a Floating License? – Automation Software Systems
Analog Instruments
Emerson Smart Wireless gateway
Modbus Function Codes and Addresses
Integral Wind-Up Limitation
What is Integral Wind Up ?
compressor emergency shutdown system
Compressor Emergency Shutdown Root Cause Analysis
Sources of Static Grounding and Methods to Control
Node-RED in PLC Automation
Controller Output Current Loop
DCS Controllers to Output Current Loops
Stripping tower unit
Thermocouple simulator
Problems of Reference Junction Compensation : Thermocouples
Online time of the PLC
System and Local Time in PLC
Calibration Standards
Practical Calibration Standards
Latched and Momentary Operation of Motor PLC Program
Electrical Machines MCQ Series 18
Why Fiber Optic Cable is Spliced rather than Termination
Why Fiber Optic Cable is Spliced rather than Termination?
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
SIS Application Program - Safety Instrumented System
SIS Application Program – Safety Instrumented System
