Reading: How to Delay a Sensor Signal in PLC?
Inst Tools > Blog > PLC Tutorials > How to Delay a Sensor Signal in PLC?
Learn how to delay a sensor signal in the PLC function block programming with the help of on-delay timer code.
Last updated: September 28, 2022 2:24 pm
Hussien Ghareb
First of all, and before we getting into our code, we should know:
Why do we need to Delay a Sensor Signal?ExampleNow It’s PLC Coding TimeDownload the Logic
As an operator one of the best features of your plant or process is the speedy response of your system (level sensors, pressure switches, actuators ….) that would really help you to control and monitor your plant easily, but as all of us know
“There is no fixed rule in our life”, there would be some other situations that really need the signal of some sensors in the plant to be delayed, look for the next alternative situation.
Example
We have a storage tank in our process that maintain a certain level of (seeds, water, oil ….), this tank has a high-level switch.
When this level is on the whole process would start, for some reasons (some of the seeds touch the sensor when you fill up the silo) you may found the level sensor has a deceptive signal for just 100msec and this could happen several times. Such a problem would really make some Significant losses to your system.
So, here is the simple solution with just 2 or may 3 second delay for the level signal you will ensure that is the real signal of the switch and your silo is definitely is full.
NOTE do not make a long delay as that could make another issue and negative effects with the process.
Our code is built using just function as there is no need to use a function block.
First of all, we are calling the function that is responsible for delaying the desired sensors from the main OB (Organization Block).
As said before, the structure and organization of the code is a very critical point that you should be aware of.
Now we are in the function (FC1) that contains the blocks that control the sensor signals.
The first Network is a timer that responsible for initializing a pulse every one second.
The other networks contain the function that responsible for delaying the sensor signal (FC2)
  • “ONDLY-TMR” is the function
  • CONTACT-IN – It is the real-time sensor signal getting from the field.
  • PULSE – it’s a one-second pulse from the first network that makes the delay between counts.
  • DELAY-SET – It is the No. of set counts (this set is converted to seconds).
  • DELAY-COUNTER – It is the counter that will be compared with the set value
  • CONTACT-OUT – It is the delayed signal that you can put on Marker or Data Block to reuse it.
On Delay Timer in Siemens PLC
Here we have our Logic that handles the desired function with some comments to make it easy to understand…
PLC Timer Code
Download the Logic
  1. CALL DLY ON (FC1)
  2. ONDLY-TMR (FC2)
Code Made By Sachen
  • PLC Practice Questions
  • Basics of Ladder Diagram
  • Electrical Circuit Schematic
  • How to Choose Right Fuse?
  • PLC Trainer Demo Download
How to Take Program Backup from Physical PLC? – Siemens PLC
How to do Scaling for Analog Input in RSLogix 500?
Software Redundancy in Siemens PLC – Hardware versus Software
Will PLCs become obsolete?
PLC Interlock Logic with First Input Priority
Comparator in PLC Programming
T-Junction Traffic Control System – PLC Programming
SFC Language in PLC Programming
Single-acting Pneumatic Cylinder Operation with Limit Switch
Automation System for Hazardous Environments
PLC Programming Example on Timers Function Block
Basics of Loop Checks
The Concept of Shift Register in Omron PLC with Example
SCADA Standards
SCADA for Substation Automation
Historical Scada graph
Configuration of InTouch Scada Trends
How to Choose HMI
How to Choose a Suitable HMI for Your Application?
How to Download Rslogix Free
Download Allen Bradley RSLogix PLC Software
PLC Ladder Logic Chemical Mixing Process
Chemical Mixing Process using PLC
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
HMI book
HMI Handbook
Power Systems MCQ Series 13
Control Valves Flow Direction
Control Valve Flow Direction
Difference Between PNP and NPN Sensors
LVDT Principle
Contact Vibration Measurement
PLC Program for motor operation based on time cycle
PLC Motor Operation based on Time Cycle Sequence – Program
Weight-based Level Instruments Principle
Weight-based Level Measurement Principle
Orifice Plate
Orifice Plate Questions and Answers
Dual Converters Multiple Choice Questions
