Reading: How does SMPS Works? – Switched Mode Power Supply
Inst Tools > Blog > Animation > How does SMPS Works? – Switched Mode Power Supply
SMPS stands for Switched Mode Power Supply. In this article, you will learn how does SMPS works and their principle.
Last updated: May 23, 2023 2:30 pm
Animation Electrical Basics Electronic Basics PLC Tutorials
In this post, we will see the working of SMPS.
Switched Mode Power SupplyInput Rectifier and FilterHigh-Frequency ConverterPower TransformerOutput Rectifier and FilterControl Circuit
SMPS stands for Switched Mode Power Supply. It is an essential part of an electrical power circuit.
Basically, power is required in different forms for various circuits. So, we just cannot feed raw AC power to them. Such type of conversion is done by SMPS. Its role is to provide the necessary supply voltage to electrical circuits in their required form.
As the name implies, the power supply is altered and obtained in various forms by means of switching devices inside it. They switch the power in various ways to provide the final output voltage.
These switching devices are nothing but power electronic devices like triac, diac, transistor, MOSFET, capacitors, resistors, etc.
SMPS is majorly categorized into four types –
  1. AC to DC converter,
  2. DC to DC converter,
  3. Forward converter, and
  4. Flyback converter.
In this post, we will have a look at the working of one of the most widely used types – AC to DC converter.
AC to DC converter is used to provide regulated DC supply voltage to electrical circuits. The 230V AC supply is converted to a 24V DC supply. Let us have a look at the inside circuit of this converter.
As seen in the below figure, the SMPS consists of an input rectifier and filter, a high-frequency switching device converter, power transformer, output rectifier, and filter and control circuitry.
Let us see the function of each of these components.
Switched Mode Power Supply (SMPS)
This is the primary stage of the converter. The rectifier and filter circuit is used to convert AC supply into DC voltage.
But this DC output voltage is unregulated. It has many variations as the circuit inside is only used to convert and not process it accurately.
This unregulated DC voltage is then given to a high-frequency converter consisting of switching devices.
This is the main heart of SMPS. Because the incoming DC voltage is unregulated and not processed properly, it cannot be directly fed to the output circuit.
So, the processing task is done by power-electronic switching devices. Power transistor, MOSFET, diac, triac, etc. are employed here which switches on and off according to variations.
These switching devices have very low resistance and they are capable of resisting high currents. They thus create high frequency pulsating DC signal; which is processed properly and less variable.
Power Transformer
The high-frequency DC output is fed to the power transformer for step-down reduction.
The high voltage DC output is converted into a low voltage DC output.
Switched Mode Power Supply Animation
The output from the transformer is again fed to the rectifier and filter circuit to get a constant and steady DC output voltage.
Basically, this filter smoothens the DC output.
Control Circuit
Similar to PID philosophy, the output from rectifier is again fed to the high-frequency device for feedback error control logic.
This is done to ensure that we get a constant DC output voltage every time. The deviations are monitored and nullified again by the whole circuit once again.
SMPS find their application in almost every electrical circuit, as most of the devices require DC voltage; and not just DC voltage, SMPS provides a regulated voltage as discussed before in the types of SMPS.
  • What is a Wet Contact?
  • Preventive Maintenance of VFD
  • Why 24 Volts DC Power Supply?
  • Commissioning and Testing of PLC
  • Automation Engineer Troubleshooting
Normally-open and Normally-closed Switch Contacts
How to Convert Voltage to Current using Resistor ?
Configuration of Siemens VFD Using TIA Portal Start drive
Step by Step Guidelines to Download Free Robotics Software
Motor Maintenance, Troubles, Regular Checks, Performance
PLC Conveyor Ladder Logic Program
PLC Logic for Analog Alarms using Functional Block Diagram
Studio 5000: Programming Three Motors with Fixed Priorities
Studio 5000 Tutorial: PLC Programming for Digital Alarms
What are Analog Inputs? – Analog Signals Processing in PLC
Siemens Process Mode
Test and Process Modes in Siemens PLC
How PLC controls a ON-OFF Valve
PLC Valve Control Ladder Logic Programming
PLC Program for Star Delta Starter using Functional Block Diagram
Bit Shift Registers PLC Program
PLC Light Sequence Control using Bit Shift Registers
Ladder Logic Vs. Other Programming Languages - PLC Basics
Ladder Logic Vs. Other Programming Languages – PLC Basics
Procedure For reading or searching the tag number in Siemens PLC
Procedure for Reading or Searching the Tag number in Siemens PLC
Two Hand Control Logic
Two Hand Control Logic using PLC
Compressor and Compressor valves Maintenance
Compressor & Compressor Valves Maintenance
Pressure Gauge Water traps and pigtail siphons
Pressure Gauge Water Traps and Pigtail Siphons
double-ported globe valve
What is Double-ported Globe Valve ?
Sorting and Counting Products on Conveyors by Color
PLC Programming for Multi-Color Sorting Conveyor System
Thermocouple Questions and Answers
Benefits of SIMOCODE over Intelligent MCC
Modbus Simulator Softwares
Career Scope in Mechanical Engineering
