You measure a lot of things daily. Have you wondered when it started first? When did man measure something for the first time?
So let’s go back in time in a period of 3000 BC. Humans used to wander here and there. After some time they settled at one place near a water source like a river.
Gradually they started farming. All people use to perform different actives and exchanged things in between them for livelihood. Some were cultivating vegetables and some were cultivating fruits etc. They used to exchange fruits or vegetables and more many other similar things.
People have been measuring since they began to buy, own and sell things, which means that the history of measurement is as long as that of civilization.
And here comes the measurement in scope. Now humans need some system so all things are equally distributed. The earliest known records of measurement originated in 3000 BC in Egypt. Measurement evidence was found during the building of pyramids.
The cubit is defined as the length of the Pharaoh’s forearm plus the width of his hand.
Once this measurement has been made and carved into a granite block, wooden and stone copies are given to builders. Architects have the responsibility to check them each full Moon with execution the penalty if they don’t.
In today’s scenario, we need to check periodically with National Standards, International Standard or with physicals constants.
In ancient times, the body ruled when it came to measuring. The length of a foot, the width of a finger, and the distance of a step were all accepted measurements.
History of Measurement
Some of the olden measurement units are as follows:
Inch: At first an inch was the width of a man’s thumb. In the 14th century, King Edward II of England ruled that 1 inch equaled 3 grains of barley placed end to end lengthwise.
Hand: A hand was approximately 5 inches or 5 digits (fingers) across.
Span: A span was the length of the hand stretched out, about 9 inches.
Foot: In ancient times, the foot was 11 inches. Today it is 12 inches, the length of the average man’s foot.
Yard: A yard was originally the length of a man’s belt or girdle, as it was called. In the 12th century, King Henry I of England fixed the yard as the distance from his nose to the thumb of his outstretched arm. Today it is 36 inches.
Cubit: In ancient Egypt, a cubit was the distance from the elbow to the fingertips. Today a cubit is about 18 inches.
Lick: A Lick was used by the Greeks to measure the distance from the tip of the thumb to the tip of the index finger.
Pace: The ancient Roman soldiers marched in paces, which were the length of a double step, about 5 feet; 1,000 paces was a mile. Today, a pace is the length of one step
All these units used various body parts of kings. It was localized units. When man used to trade in different cities it was occurring problems.
Starting in the 18th century, Slowly this localize system developed into modernized, simplified, and uniform systems of weights and measures with the fundamental units defined by ever more precise methods in the science of metrology.
This system slowly evolved into CGS system, MKS system and SI System. SI system is widely accepted today.
History of Measurement is as follows:
1799, Paris
The metric system is set up, through the adoption of two platinum/iridium alloy standards: a metre, length and a kilogram mass.
1875, Paris
Seventeen nations sign the Convention of the Metre, and the International Bureau of Weights and Measures is set up.
1960
The International System of Units (SI System) is established, including units of mass, length, time, temperature, current and luminous intensity.
1971
A seventh unit, of amount of substance, is added to the set of SI base units.
2019
New definitions of the base units were approved on 16 November 2018, and took effect on 20 May 2019.
All seven SI base units are defined by fundamental physical constants.
Seven SI base unit
(All seven SI units are defined is by fundamental physical constants.)
| Measure | Unit |
| length | meter |
| mass | kilogram |
| time | second |
| current | ampere |
| temperature | kelvin |
| amount of substance | mole |
| luminous intensity | candela |
