Reading: Hierarchy of Calibration Organizations
Inst Tools > Blog > Calibration > Hierarchy of Calibration Organizations
The calibration hierarchy helps us to record the sequence of calibrations performed on an instrument from a reference standard to the final measuring system.
Last updated: September 28, 2022 3:24 pm
Saurabh Vaidya
Calibration
Calibration StandardsCalibration Organizations
Any type of local calibration performed in-house of an industry must be compared with a national standard and it must be documented.
It helps us to ensure proper record of instrument traceability.
There are different levels of calibration standards available from national level to the local level.
We calibrate our instruments in our Local Calibration lab. The local calibration lab is accredited by NABL in India (National Accreditation Board for Testing and Calibration Laboratories). I.e. NABL is one level up from the local calibration lab. Similarly NABL is accredited by APAC and APAC is accredited by ILAC.
International Laboratory Accreditation Co-operation (ILAC) is Apex Organization.
ILAC is the international organization involved in the accreditation of conformity assessment bodies including calibration laboratories and testing laboratories.
As quality of product or Calibration results should be same all over the world, ILAC organization is formed to keep checked on this results.
As this body cannot reach every part of world, it has branches all over the world name as Regional Offices. Eg- EA, APAC, etc…
ILAC and IAF (International Accreditation Forum) work together and coordinate their efforts to enhance the accreditation and the conformity assessment worldwide.
Around the world, geo-political regions such as the European Community, and Asia-Pacific, the Americas and others, established regional cooperation to manage the work needed for such mutual recognition.
Regional Co-operation bodies under ILAC are EA in Europe, APAC in the Asia-Pacific, IAAC in America, AFRAC in Africa, SADCA in Southern Africa, and ARAC in the Arab region.
Regional Cooperation Bodies are those whose regional Mutual Recognition Arrangements (ILAC MRA) have been successfully peer-evaluated by ILAC.
ILAC and all regional bodies ensure that all accredited laboratories comply with ISO 17025 (for calibration and Testing).
EA– European Accreditation Cooperation
APAC– Asia Pacific Accreditation Cooperation
IAAC – Inter-American Accreditation Cooperation
 AFRAC – African Accreditation Cooperation
SADCA – Southern Africa Accreditation Cooperation
ARAC– Arab Accreditation Cooperation
EA has 50 Members. EA also cooperates with EURAMET (European Association of National Metrology Institutes) to publish several guidelines useful for accreditation calibration laboratories.
APAC was established on 01 January 2019 by amalgamation of two former regional accreditation bodies APLAC (Asia Pacific Laboratory accreditation cooperation) and PAC (Pacific accreditation cooperation). It has 48 full members across 29 Countries, 17 Associate Members and 6 Affiliates. NABL is one of the Full members.
National Accreditation bodies provides accreditation to calibration laboratories in respective countries.
National Accreditation bodies are UKAS in the UK, FINAS in Finland, NABL in India, A2LA in USA, and SANAS in South Africa.
UKAS– United Kingdom Accreditation Service
NABL– National Accreditation Board for Testing and Calibration Laboratories
A2LA– American Association for Laboratory Accreditation
SANAS – South African National Accreditation System
Respective National Accreditation bodies are Member of Regional Co-operation bodies and ILAC.
  • History of Measurement
  • Selection of Master Instrument
  • Importance of Unit Measurement
  • Why Calibration is Important?
  • RTD Testing in Calibration Laboratory
Pressure Safety Valves Functional Testing
Calibration of Gas Detectors
Pressure Safety Valve Leak Test Procedure (PSV Testing)
How to Create Calibration Records?
Multiple Position Calibration of Temperature Chamber
pH sensor calibration procedure
Why it is important to note As-Found and As-Left data during Calibration?
Impulse Line Pressure Testing Procedure
Stability and Uniformity of Temperature Bath
Difference between Accuracy, Tolerance, Uncertainty, and Error
Field Instrument Calibration Errors
Calibration : Up-tests and Down-tests
Closed tank DP Level Transmitter with wet leg elevation zero remote mount Calibration
Difference between Repeatability and Reproducibility
How to Calibrate pH Electrode?
SMART Transmitters Block Diagram
Smart Transmitters LRV & URV
Parts of the Temperature Calibrator
What is a Dry Block? – Parts of the Temperature Calibrator
Calibration of a Strain Gage Load Cell
Shunt Calibration of a Strain Gauge Load Cell
Instrument Linearity Error
Instrument Errors – Zero, Span, Linearity
Displacement Level Transmitter in situ calibration
Displacer (buoyancy) Level Transmitter Principle, Limitations, Design, Installation & Calibration
Electrical Engineering Documents
Electrical Engineering Documents – Engineers Questions
How to do Force in GE PLC Proficy Machine Edition?
Scan cycle of a Siemens PLC
OB1 – Main Cyclic Organization Block in TIA Portal
Digital output block add-on for Variable speed drive
Steps to Import PlantPAx Add-On Instructions in Studio 5000
different types of threads based on 4 standards
Different Types of Threads based on 4 Standards
Densitometers Principle
Vibrating Tube Densitometers Working Principle
Typical Switchyard Layout
Electrical Substation – Busbar Arrangements and Layouts
