Reading: Globe Valve Seat and Disk
Inst Tools > Blog > Control Valves > Globe Valve Seat and Disk
Last updated: March 21, 2019 3:43 pm
Control Valves
3 Min Read
Most globe valves use one of three basic disk designs: the ball disk, the composition disk, and the plug disk.
Globe Valve Disk and Stem ConnectionsGlobe Valve SeatsGlobe Valve Direction of Flow
Ball Disk
The ball disk fits on a tapered, flat-surfaced seat. The ball disk design is used primarily in relatively low pressure and low temperature systems. It is capable of throttling flow, but is primarily used to stop and start flow.
Composition Disk
The composition disk design uses a hard, nonmetallic insert ring on the disk. The insert ring creates a tighter closure. Composition disks are primarily used in steam and hot water applications.
They resist erosion and are sufficiently resilient to close on solid particles without damaging the valve. Composition disks are replaceable.
Plug Disk
Because of its configuration, the plug disk provides better throttling than ball or composition designs. Plug disks are available in a variety of specific configurations. In general, they are all long and tapered.
Globe valves employ two methods for connecting disk and stem: T-slot construction and disk nut construction.
In the T-slot design, the disk slips over the stem. In the disk nut design, the disk is screwed into the stem.
Globe Valve Seats
Globe valve seats are either integral with or screwed into the valve body. Many globe valves have backseats.
A backseat is a seating arrangement that provides a seal between the stem and bonnet. When the valve is fully open, the disk seats against the backseat.
The backseat design prevents system pressure from building against the valve packing.
For low temperature applications, globe and angle valves are ordinarily installed so that pressure is under the disk.
This promotes easy operation, helps protect the packing, and eliminates a certain amount of erosive action to the seat and disk faces.
For high temperature steam service, globe valves are installed so that pressure is above the disk. Otherwise, the stem will contract upon cooling and tend to lift the disk off the seat.
Articles You May Like :
Applications of Needle Valves
What is Stop Check valve ?
Control Valve Software
Electrical & Hydraulic Actuators
JT Valve Working Principle
Facts About Control Valves
Control Valve Working Animation
Exclusive Control Valve Sequence
How Globe Valves Work ?
How to Troubleshoot Control Valve? – Problems and Solutions
Solenoid Valve Troubleshooting Tips
Basic Steps and Procedure for the Repair of Control Valve
What is a 3-way Solenoid Valve ?
How Needle Valve Works ?
What is Pinch Valve ?
What is a Servo Valve? – Principle and Advantages
Control Valve Fail Safe Action
Spring and Diaphragm Pneumatic Actuators
progressively sequenced control valves
Progressive Control Valve Sequence
Control Valve Parts
Control Valve Parts Questions and Answers
Self-actuated Temperature Regulator
Self-actuated Temperature Regulator – Principle, Types, Advantages
Trip Valve Shown Tripped
Trip Valve Principle
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Solenoid Valve Functional Testing
Dual Solenoid Valve on Control Valve
Why we Require Dual SOV on a Control Valve?
Difference Between the Control Valve and Shut-off Valve
Dead Time and Reclaim Time
What is Auto Reclosing?
FIFO and LIFO Sequences in PLC
What are FIFO and LIFO Sequences in PLC?
Single-acting Pneumatic Cylinder operation with Limit Switch
Single-acting Pneumatic Cylinder Operation with Limit Switch
Interview Questions on Battery Testing
Automatic Car Door Simulation
Automatic Door Operation PLC Programming and Simulation
Differential Pressure Transmitter Wet Leg Compensation
Differential Pressure Transmitters Compensated Leg Systems
Industrial IoT Job Roles and Responsibilities
IoT Engineer Job Roles and Responsibilities
Sink or source PNP or NPN Normally Open or Normally Closed Input v. output. output
