Reading: Functional Safety Terminology in Industrial Automation
Inst Tools > Blog > Control Systems > Functional Safety Terminology in Industrial Automation
Learn the functional safety terminology used in industrial automation. Learn fail-safe operation and reduce risks to personnel and equipment.
Last updated: September 16, 2024 2:18 pm
Control Systems
6 Min Read
In industrial automation, there is always a safety hazard due to the use of critical machines and equipment around. The personnel working around must be felt safe and also the process must be executed smoothly. For this, it is necessary to implement certain safety conditions in a plant for fail-safe operation. This is called functional safety in easier terms.
What is functional safety?TerminologySafety Instrumented SystemSafety Integrity LevelRisk AssessmentIEC-61508Safety FunctionsSafety Circuit StructureDiagnostic Coverage
There are many terms related to functional safety which are used generally for understanding purposes. In this post, we will see some general functional safety terms related to industrial automation.
Functional safety is a theory and practice which involves understanding all the safety hazards and then checking how to solve them. This reduces the risk to the environment, personnel, and the machines around. Any untoward incident can occur if it is not resolved and predicted on time.
There are certain steps to be followed when designing a safety feature, like first analyzing the risk, then checking the issue, and then seeing how it can be resolved. When finally a functional safety system is designed, it ensures the automatic shutdown of a plant safely and properly removes all the hazards by solving them.
Functional Safety Terms in Industrial Automation
Terminology
Now, let us see some general terms related to functional safety in an industrial plant.
SIS means to add an extra layer of safety in a controlled automation system. This means, that if a process has two sensors for control, then a third sensor will be added as the master controller which will override the other two if it senses a fail situation.
Here, it basically deals with adding some critical master sensors and actuators for safely shutting down a process. It also involves the use of a safety PLC in place of standard PLC.
This level is used to indicate how critical safety is for a system. It is usually categorized from SIL-1 to SIL-5.
As the level increases, it shows that safety requirements to increase. For that, certain design conditions come as to what an instrument should be, how many loops can be created for safety, how many backup instruments will be present, and all.
Risk Assessment
As the name implies, risk assessment deals with analyzing the risks involved in operating a plant. Accordingly, the failure conditions will be determined, its consequences will be raised and then, how it needs to be solved will be studied. If this factor is high, then safety standards too must be maintained accordingly.
IEC-61508
IEC 61508 is an international standard that an automation system implementer must follow for fail-safe plant conditions. IEC 61508 has its own set of rules and framework that deals with safety-related operations, determining potential hazards, and removing them before they can affect a system. It has many parts and guidelines in it for helping the engineers design a system for safe operation.
Safety Functions
Safety functions consist of various processes like the use of safety drives, safety remote IO’s, safety networks, and use of features in a drive like safe torque off (STO), safe stop-1, and safe operating stop (SOS).
Safety functions also involve the use of specially designed safety devices like safety mats, safety switches, and safety power switching devices. All these generally make a part of a safety function that can be customized as per requirement.
A safety circuit structure is used to design a system as to how the instruments or sensors will be configured. This means a normal system will have only one sensor for one PLC input.
But here, you can design circuits where you will have 2 sensors connected parallelly for a single PLC input, or where one field sensor will be distributed to two PLC inputs. This type of example here is called 1oo2 architecture.
Similarly, you can customize as per your design and the motive here is to create a redundancy for the field sensors and devices.
Diagnostic Coverage
For making a safe system, intense monitoring is required and diagnostic coverage involves what type of signals can be taken from an instrument, how many states can be designed in a controller program for alarm conditions, or how visually you design a SCADA screen for showing diagnostics.
A great diagnostic coverage with no use of unwanted signals can create a great safety system as the operator gets to reach out to problems easily.
In this way, we saw some general and most used terms related to functional safety in industrial automation.
  • Safety Instrumented System book
  • SIS Component Selection Theory
  • What is a Process Override Switch (POS)?
  • Emergency Shutdown Button Installation
  • High Integrity Pressure Protection Systems
DCS Troubleshooting Control Valve Loop
Design View of Supplying Process Control and Safety Systems
Tips for Reducing the Noise Signals
Why we use Diode Protection Modules ?
Chemical Reactor Temperature Control System
PID Tuning Recommendations based on Process Dynamics
Heat Exchanger Temperature Control
How Valve Positioners act as Cascade Control Systems in a Loop?
Flexible Input Output Modules
Limit Controls : High Limit & Low Limit Functions
4-20mA Junction Box versus Fieldbus (FF) Junction Box
List of 100 Distributed Control Systems Questions (DCS)
Boiler Drum Level Control Systems
PID Controller Bumpless Transfer
What is PID Controller Bumpless Transfer ?
Industrial Automation and Control Systems (IACS)
PID Controller Tunning Manually
PID Controller Parameters Tuning Manually
Steady-state process gain
Steady-State Process Gain
Most Common Types of Cyber Attacks
20 Most Common Types of Cyber Attacks
Transducer
What is a Transducer ?
Emergency Stop Push button
Pressure Transmitter Parts
Differential Pressure Transmitter Working Principle
Factory IO PLC Course
Factory I/O PLC Automation Training Course (Free)
Digital Electronics MCQ
1’s, 2’s, 9’s & 10’s Complements Objective Questions
Electronic Devices & Circuits Quiz – Set 15
Quiz on Manual Motor Starters
100 Quiz Questions on Manual Motor Starters
Different RTD Types
Difference between PT100, PT1000, Nickel RTD and Balco RTD
Lift check valves
What is Lift Check Valve ?
Rotameters Working
Rotameter Working Principle and Animation
