Reading: Effects of Long Distance Cables between VFD and Motor
Inst Tools > Blog > Electrical Basics > Effects of Long Distance Cables between VFD and Motor
In this post, we will learn the effect of the long distance cables between VFD and motor, and why it must be avoided.
Last updated: December 7, 2022 12:13 pm
Electrical Basics
2 Comments
6 Min Read
The Variable Frequency Drive (VFD) is a very important element in motor speed control. You can get any desired speed with the use of VFD.
But, do you know that the distance between a motor and a VFD matters too? It may not sound too interesting, but it is a fact that the distance between the motor and the VFD is one of the important factors in running a motor efficiently and for longer life.
In this post, we will learn the effect of the long distance between VFD and motor, and why it must be avoided.
Why must the distance between the Motor and VFD be Shorter?
Effects of Long Distance Cables on VFD
It must be noted that the typical distance between VFD and the motor should not exceed 30 meters. Why? Let us get into the fundamentals now. The output of VFD is a sine wave. For a variable sine wave to properly control the speed of the motor, the cables, VFD, and motor must all be properly grounded. This is the very first step in the topic.
Now, as we are discussing the cable length, the cable must be properly shielded in its very first place. If the cable is properly armoured and grounded, then the noise generated within the cable is confined to itself only.
Otherwise, the noise will be disbursed outside the cable too, and the higher the noise, the higher will be the leakage current generated. And if the distance is long, then the noise will spread over more area, and the chances of the motor getting damaged will increase more. So, this is the very first step in distance point – the cables must be properly grounded, be they shorter or longer distances.
Now, let us move on to the next point. It is to be noted that a capacitance always exists in the sine wave current (PWM signal) flowing in VFD cables to the motor. One of the main issues faced in this is voltage reflection. When the distance is long, the impedance of the power cables and the motor is not consistent. It is mostly consistent in shorter distances.
Now, if a normal PWM signal is flowing and if this impedance collides with it, then there will be high chances of voltage reflection. Impedance plays a very important role in PWM signals. When the drive sends output sine waves down the cable to the motor, they reach the motor and due to the motor’s impedance, reflect back towards the drive, while the drive is continually sending sine waves to the motor.
Coming back to the earlier point of the effect of capacitance, the capacitance from the cables (phase to ground) too can create enough current to ground where there can be nuisance ground fault trips.
These two factors – capacitance and voltage reflections due to improper impedance, can cause the reflected wave could be added to the fundamental waveform coming from the drive resulting in a significantly higher voltage at the motor terminals.
So, if the distance is longer, then there will be more chances of unbalanced voltage peaks in between (due to the issue discussed earlier). This will also increase rise steepness (dv/dt) to a large extent. If the rise is more and unstable, then the voltage peaks will occur frequently.
Both the maximum value of the voltage pulse and the rise steepness (dv/dt) are dangerous for the motor insulation. Due to this, the motor will not operate properly, and also, after a certain period of time, the insulation and bearings of the motor will get damaged.
The long-distance connection will generate surge voltage at both ends of the motor winding, the superimposed surge voltage will increase the winding current of the motor and the motor temperature, thus damaging the winding insulation.
This shows that the distance between VFD and the motor must be tried to keep not too long. There are many ways to counter this; because suppose you are placing a VFD in the central room, then the motor will always be at a larger distance at the field site. It is a completely different topic, and we cannot elaborate here. Our main purpose was to first understand the effect of the long distance between the VFD and the motor.
In this way, we understand the effects of long-distance cables on VFD and motor.
  • Auto Changeover Switch
  • How do AC Drives Work?
  • What is a Solid State Relay?
  • What is Transformer Bushing?
  • Variable Frequency Drive (VFD)
Induction Motor Over and Under Voltage Problems
What is an Instrument Transformer? – Types, Principle, Advantages
Motor Maintenance, Troubles, Regular Checks, Performance
How to Read and Understand an Electrical Single Line Diagram?
Difference Between HV and LV Cables
Difference between Soft Starter and VFD
2 Comments
  • Darren Ash says:
    December 14, 2022 at 5:17 am
    Have never heard the output of a VFD described as a sine wave. You would need a sine wave filter for that function to convert from PWM output to an actual sine wave.
    You get to the description later in the article, but takes effort to get from PWM to an actual sine wave. dv/dt will help with peaks but on a scope still looks like a PWM signal.
    All VFD manufacturers I have worked with have technical documents that cover required cable specifications based on distances and the needed reactors or filters depending on distance. You must refer to the manufacturer recommendations as not all drives have equivalent control algorithms. Some have software based reflective wave mitigation built-in to the firmware that may require different recommendations than another vendors drive.
  • AMIN MOHAMMADI says:
    August 14, 2023 at 3:33 pm
    Dear engineer , Viral Nagda
    Hello
    Thank you for your very helpful and clearly written article. And I wish you the best.
    I thank all the staff of the site ” Instrumentationtools.com”
Partial Discharge in Power Lines and its Detection through Sensors
Why is IGBT used in VFD?
What is a Substation? Purpose of an Electrical Substation
Corona Discharge in Power Transmission Lines
What is Variable Air Volume Controller in HVAC?
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Types of Motor Loads – Constant & Variable Torque, Horsepower
Difference Between Earth and Neutral
Connection between PLC and Contactor
Motor Controls
Design and Implement Motor Control – Electrical Engineering
Intelligent Motor Control Center
What is an Intelligent Motor Control Center? – IMCC
Garage Door Roller Shutter
Routine Tests of Transformers
Transformer Testing – Routine Tests of Transformers
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
Difference Between Regenerative and Dynamic Braking
Top 100 555 Timer Projects for Engineering Students
Hierarchy of Calibration Organizations
Cobot - Collaborative Robot
What is Cobot? – Collaborative Robot
Valve Bellows seal
Bellows Seal Valve Working Principle
PRV
Pneumatic Systems Objective Questions
Absorption Instrumentation Questions & Answers
ControlLogix Architecture - Rockwell Automation
ControlLogix Architecture – Rockwell Automation
