Reading: Discharge and Charging of Lead-Acid Battery
Inst Tools > Blog > Electrical Theory > Discharge and Charging of Lead-Acid Battery
Last updated: July 27, 2018 6:12 pm
Electrical Theory
In a lead-acid battery, two types of lead are acted upon electro-chemically by an electrolytic solution of diluted sulfuric acid (H2SO4). The positive plate consists of lead peroxide (PbO2), and the negative plate is sponge lead (Pb), shown in Figure 4.
Lead Acid Battery Discharge
Figure 4 : Chemical Action During Discharge
When a lead-acid battery is discharged, the electrolyte divides into H2 and SO4 combine with some of the oxygen that is formed on the positive plate to produce water (H2O), and thereby reduces the amount of acid in the electrolyte. The sulfate (SO4) combines with the lead (Pb) of both plates, forming lead sulphate (PbSO4), as shown in Equation.
lead-acid battery discharge equation
As a lead-acid battery is charged in the reverse direction, the action described in the discharge is reversed. The lead sulphate (PbSO4) is driven out and back into the electrolyte (H2SO4). The return of acid to the electrolyte will reduce the sulphate in the plates and increase the specific gravity. This will continue to happen until all of the acid is driven from the plates and back into the electrolyte, as shown in below Equation and Figure 5.
Lead Acid Battery charge
Figure 5 : Chemical Action During Charging
lead-acid battery charge equation
As a lead-acid battery charge nears completion, hydrogen (H2) gas is liberated at the negative plate, and oxygen (O2) gas is liberated at the positive plate. This action occurs since the charging current is usually greater than the current necessary to reduce the remaining amount of lead sulfate on the plates. The excess current ionizes the water (H2O) in the electrolyte. Since hydrogen is highly explosive, it is necessary to provide adequate ventilation to the battery whenever charging is in progress. Also, no smoking, electric sparks, or open flames are allowed near a charging battery.
The decrease in specific gravity on discharge is proportional to the ampere-hours discharged. While charging a lead-acid battery, the rise in specific gravity is not uniform, or proportional, to the amount of ampere-hours charged (Figure 6).
Voltage and Specific Gravity During Batteries Charge and Discharge
Figure 6 : Voltage and Specific Gravity During Charge and Discharge
The electrolyte in a lead-acid battery plays a direct role in the chemical reaction. The specific gravity decreases as the battery discharges and increases to its normal, original value as it is charged. Since specific gravity of a lead-acid battery decreases proportionally during discharge, the value of specific gravity at any given time is an approximate indication of the battery’s state of charge.
To determine the state of charge, compare the specific gravity, as read using a hydrometer, with the full charge value and the manufacturer’s published specific gravity drop, which is the decrease from full to nominal charge value.
Example:
A lead-acid battery reads 1.175 specific gravity. Its average full charge specific gravity is 1.260 and has a normal gravity drop of 120 points (or.120) at an 8 hour discharge rate.
Solution:
Fully charged – 1.260
Present charge – 1.175
The battery is 85 points below its fully charged state. It is therefore about 85/120, or 71%, discharged.
Current Division
Power Triangle
Types of AC Generators
Series-Wound Motor
DC Circuit Analysis Node Equations
Battery Hazards
D’Arsonval Meter Movement
AC Generator Theory
Types of Capacitors
AC Generation Analysis : Effective Values, Phase Angle and Frequency
Types of Batteries
Induction Motor Torque Versus Slip
Battery Terminology
Impedance
Capacitor Principle
Capacitor
Current in a Capacitor
Capacitance and Capacitive Reactance
Parallel Circuit Unknown Resistance
Simplified Formulas for Parallel Circuit Resistance Calculations
Electric Short Circuit
Series Short Circuit Faults
Transformer Efficiency and Loses Formula
Forward Bias
Rectifiers, Forward Bias and Reverse Bias
Basic AC Generator
AC Generator Parts
Three Phase Wattmeter principle
Ampere Hour Meter
Pressure Gauge Parts
Pressure Gauges with Bourdon Tube Principle
TON Timer in RSlogix
Why is RTO used in the Place of TON Timer?
Importance of Hysteresis Loop
Instrumentation Project Documents
List of Instrumentation Project Engineering Documents
pressure transmitter calibration setup
Why Pressure Vessel Connected to Tubing System?
Frequency Division Multiplexers Objective Questions
PLC Program for Two ways switch logic for staircase light
PLC Program for Two Way Switch Logic
Turbidity Sensor Calibration Procedure
