Reading: Digital Control Valve (DCV) Calibration Procedure
Inst Tools > Blog > Guest Articles > Digital Control Valve (DCV) Calibration Procedure
Last updated: December 22, 2018 12:18 am
Guest Articles
3 Min Read
CALIBRATION PROCEDURE FOR DIGITAL CONTROL VALVE
The below calibration procedure for Digital Control Valve. Make : Fisher, Model :  DVC 6000
Also Read : Digital Control Valve Principle
Tools Required:
1. 375 Field communicator
2. Tools kit
3. DATA sheet
  1. Take the work permit from shift in-charge
  2. Checking for valve accessories any damage for DVC feed back, guage, air regulator and filter
  3. Check the pressure regulator guage and set it according to bench set
  4. Check the positioner cam alignment ,cam alignment should be matched with travel length
  5. Operate the valve from DCS, observe the valve travelling condition , if it is not matching with our requirement then we have to connect the 375 field communicator at positioner terminal ( ie. Loop + and -)
  6. Switch on the communicator then select FF application in Communicator.
  7. Select required tag number from list ,then select transducer block and select configuration setup
  8. Again click basic setup enter in to setup wizard, transducer go to manual mode for performing setup
  9. As per data sheet , check the data’s whether it is matching or not
    a) Travel length
    b) Check the pressure unit (psi or kg/cm2)
    c) Check actuator manufacture and model number and actuator size
  10. Now we will go for auto calibration standard than select manual crossover adjustment
  11.  Then check visually whether feedback arm is matching with the hole of the DVC body or not?
  12. Run performance tuner and check the valve operation
  13. Calibration over than change the valve auto mode
  14. Check for valve stroke after auto calibration from DCS
TroubleShooting:
  • If Valve hunting is vigorously
    a) Go to detail setup
    b) Go to response control
    c) Click travel tuning
For fisher control valve adjust travel tuning set to lower alphabet ( If setting was D we have to select C).
For other valves we have adjust proportional gain
  • If Valve is over shooting
    c) Click pressure tuning
For fisher control valve adjust pressure tuning set to lower alphabet ( If setting was D we have to select C).
NOTE:
Relay – A = Double Acting
Relay –B = Reverse acting
Relay –C = Forward & Reverse acting
Article by
Vamsi
What is Hydraulics?
Colleges to Study Instrumentation Engineering in United States
Pros and Cons of Online Courses
Capacitance Level Switch Calibration
Blast Furnace Panel Modification to Reduce Down Time by 60 to 70%
Difference between Intrinsic Safe and Non-Intrinsic Safe Cables
Reversing Control Valve Actuator Fail Safe Mode
Safety Switches for Controlling Conveyor Operations
Compressor & Compressor Valves Maintenance
H & B Gas Analyzer Principle and Calibration Procedure
Total Organic Carbon Analyzer Principle
Pressure Gauges Common Problems
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
main controller fails
How does a Redundant Controller comes in line when the Main Controller fails?
PLC Program for Two ways switch logic for staircase light
PLC Program for Two Way Switch Logic
Open Tank DP Level Measurement
Circular Chart Recorder Calibration Procedure
Nuclear Level Measurement
Nuclear Level Detectors Cascade or Master/Slave concept
FDA Process Validation
Why You Need FDA Process Validation and How to Do It Right ?
Different RTD Types
Difference between PT100, PT1000, Nickel RTD and Balco RTD
High Integrity Pressure Protection System HIPPS
Overview of HIPPS System
Interview Questions for Instrument Engineers
PLC Signal Flow
Basic DCS/PLC Signal Flow – Video
transmitters shared for BPCS and SIS
SIS Instrument Sharing – Transmitters Shared for BPCS and SIS Example
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
hydrostatic interface measurement calculation
Hydrostatic Pressure Measurement Questions
PLC Raw Count Calculation formula for Pressure Transmitter
PLC Raw Count Calculation for Pressure Transmitter
Light Tower in Industrial Automation
