Reading: Difference Between Permittivity and Permeability
Inst Tools > Blog > Electrical Basics > Difference Between Permittivity and Permeability
In this post, we will learn the difference between permittivity and permeability.
Last updated: November 16, 2022 11:24 am
Electrical Basics
6 Min Read
What is Permittivity?What is Permeability?Difference Between Permittivity and Permeability
If you are studying magnetic fields and you do not know about permittivity and permeability, then you probably won’t be able to understand more theories deeply. They are very important terms in electromagnetism.
Because electromagnetism is used in almost every field, it is necessary to understand them.
It is a property related to the media’s electric field (vacuum, air, gas). Suppose there is a media between two conductors. Every media has an atom (electrons and neutrons). They are in an unbalanced or uneven state (which means placed anywhere in the media) without any electrical interference.
When an electric field is applied to the conductors, the atoms polarise themselves in a proper direction and this movement by them creates their own electric field, which opposes the external electrical field applied to the conductors.
They start to move away from it. This opposition is known as permittivity. It measures the opposition offered against the formation of an electric field. If they are properly aligned and moving away from the electric field, then it means that the media is having better permittivity.
It is represented by the Greek alphabet ϵ. It is calculated by the following formula – electric displacement/intensity of the electric field. It can vary depending on the type of material used, the strength of the electric field, environmental specifications of temperature and humidity, etc. So, permittivity is majorly related to the electric field.
Let me explain this with a simple example. You have two materials – iron and wood. As you know, iron is conducting and wood is non-conducting. When you place a magnet near iron, it will attract to it and when you place it near wood, it would not.
A magnet has a magnetic field around it. When a material has the ability to allow the magnetic flux to pass through it and cause attraction towards the magnet, then it is called permeability. It is a measure of the material to allow the formation of magnetic lines within its range.
The point is not only about conducting and non-conducting. It can also happen that there are two conducting materials. One will have higher permeability and one will have lower. The higher one will attract quickly even from a longer distance to the magnet; which means it has the capability of forming stronger magnetic fields with the magnet.
Permeability is denoted by the Greek alphabet μ. It is calculated by the following formula – the magnitude of magnetic induction/intensity of the magnetic field. It can vary depending on the type of material used, the strength of the magnetic field, environmental specifications of temperature and humidity, etc. So, permeability is majorly related to the magnetic field.
The main differences between permeability and permittivity are as follows.
  1. As learned earlier, permeability is related to the magnetic field, whereas permittivity is related to the electric field. Permeability is the measure of application or allowance to the magnetic field, whereas permittivity is the measure of opposition to the electric field.
  2. Permittivity is represented by the Greek alphabet ϵ, whereas permeability is represented by the Greek alphabet μ.
  3. Permittivity is calculated by the following formula – electric displacement/intensity of electric field; whereas permeability is calculated by the following formula – the magnitude of magnetic induction/intensity of the magnetic field.
  4. The SI unit (international system of units) of permittivity is Farad/meter, whereas the SI unit of permeability is Henry/meter,
  5. Permittivity is used in capacitors; whereas permeability is used in inductors and transformer cores. Permittivity is a very important quantity in electromagnetism. Usually, the materials having higher values of permittivity are highly polarizable. The higher the permittivity of a medium, the more energy is stored in the medium. Permeability is a very important quantity, especially in material sciences and engineering. For example, it is important to choose a material with high magnetic permeability when designing transformer cores and inductors.
In this way, we understand the difference between permittivity and permeability.
  • Background of Modbus
  • Instrumentation Cables
  • Plant Trip Due to Incorrect Tag
  • What is a Voltage Reference?
  • What is Gas Chromatography?
What is Automatic Circuit Recloser? Principle and Types
What is an Electrical Drive? Types, Advantages, Disadvantages
VFD Pros and Cons – Variable Frequency Drives
How do AC Drives Work? – Variable Frequency Drive (VFD)
What is Power Cable? Types of Power Cables
What is a Semiconductor Fuse?
De-energized Electrical Circuits, Networks, and Equipment
Why Do We Need to Connect Transformers in Parallel?
What are Ground Fault and Earth Fault?
Difference Between AIS and GIS Panels
Siemens Standard Drives Application Handbook (PDF)
Difference between Servo Motor and DC Motor
Variable Air Volume Controller in HVAC
What is Variable Air Volume Controller in HVAC?
Ground Rod
What is a Ground Rod?
Floating Neutral - Electrical Engineering Basics
What is Floating Neutral? – Electrical Engineering Basics
UL 489 Circuit Breaker
Difference Between UL489 and UL1077
Types of Switches
Electrical Switches Principle & Types
Electrical Motor Jogging Operation
Trip Circuit Breakers
How Do Electrical Shorts and Ground Faults Trip Circuit Breakers?
Electrical Conduit Seal
Transistor as an Amplifier in Common Emitter
Determine Voltage Drops at Respective Flow Rates
Determine Voltage Drops at Respective Flow Rates in Loop Diagram
Synchronous Machines Objective Questions
DC Machine Quiz
Omron PLC Mixing System
Mixing Program with Timers and Counters in Omron PLC
Transformer Phasor Diagram
Pneumatic Cylinder Air Flow Calculation
Sprocket Assembly and Bolting Segments
Bucket elevators Chain and teeth wear Problems
