Reading: Transmitter Current Conversion Tool
Inst Tools > Blog > Instrumentation Tools > Transmitter Current Conversion Tool
Last updated: November 12, 2019 3:44 pm
6 Comments
1 Min Read
Transmitter Current Conversion Tool or mA Conversion Tool:
This tool is used to convert the transmitter current signal from linear to square root and square root to Linear.
This calculator works in desktop/PC perfectly. For Mobile the calculator may be not properly viewed.
This calculation tool is used to find out the equivalent current linear & Square root signals.
How to Use :
  1. Select your Input Type
  2. Select your required Output Type
  3. Enter INPUT Value
  4. Press ENTER
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Level Measurement with Dry leg and Installed Below Tapping Point
Convert Linear Percentage to Square root Percentage
Convert Percentage (0-100%) to current (4-20mA)
Convert current (4-20mA) to Percentage (0-100%)
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
6 Comments
  • Inst says:
    August 7, 2015 at 11:39 pm
    I do believe everyone could learn slightly from your experience.
  • HIRENSINH says:
    August 8, 2015 at 8:46 am
    How to download this software
    • S Bharadwaj Reddy says:
      August 9, 2015 at 6:33 am
      Hi,
      These instrumentation Tools are online calculations only.
      Thanks
      S Bharadwaj Reddy
  • leet says:
    January 16, 2016 at 4:37 am
    will u give me the formula of this ma conversion
      January 16, 2016 at 4:40 am
      Hello Leet, All formulas are available in Formulas Category. Check all the posts. Thank You.
  • jakener says:
    October 10, 2017 at 6:12 pm
    Sir,please give link to download these articles
Convert Process Variable to Percentage
Level Measurement with Wet leg and Installed Below Tapping Point
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
Convert Linear mA to Square root mA
Calculate Current (4-20ma) from Process variable PV
Measurement Value to 4-20mA Signal Converter
4-20 mA to Measurement Converter Tool
Instrumentation Calculator
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
Convert-Transmitter-Output-in-Percentage-to-Process-Variable
Conversion of Transmitter Output in Percentage to Process Variable
Boiler-Drum-Level-transmitter-calibration
Boiler Drum Level Transmitter Calibration
Interface level Measurement
Interface Level Measurement using DP Transmitter
DP-Flow-Transmitter-Re-Ranging-calculation
DP Flow Transmitter Re-Ranging Calculation
DP-Level-Measurement-Calculation-Below-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
RTD Calculator : Calculate Temperature from Resistance
Installation and Maintenance of Control Valves
Advantages & Disadvantages of Variable Speed Drives
Centralized vs Decentralized Automation Systems
Function Module in Siemens PLC
What is Function Module in Siemens PLC?
Electrical & Electronics Measurements Objective Questions – Set 6
triac
Turning Off SCR – Commutation
Pneumatic Transmitter
Questions on Pneumatic Transmitter and Repeater
Difference Between Sensor and Transducer
What is the Difference Between Sensor and Transducer?
