Suppose you wish to calibrate a current-to-pressure (βI/Pβ) transducer to an output range of 3 to 15 PSI, with an input range of 4 to 20 mA. Complete the following calibration table showing the proper test pressures and the ideal input signal levels at those pressures:
Solution:
The below calibration table shows the data for applied input signal (mA) and output pressure (PSI) as per the percent of span shown in abobe figure.
Read:
Credits: Tony R. Kuphaldt
- Setpoints and Alarms
- What is Control Loop?
- 4β20 mA Process Control
- Control Valve Calibration
- Pneumatic Control Loop
