Reading: Convert Percentage (0-100%) to current (4-20mA)
Inst Tools > Blog > Instrumentation Tools > Convert Percentage (0-100%) to current (4-20mA)
Last updated: November 12, 2019 4:52 pm
1 Min Read
This is used to convert the percentage 0 – 100 % to standard current signal (ma) in the range of 4 – 20 mA.
This calculation tool used to find out the equivalent current value in ma from percentage.
Percentage to Current Conversion:
Note :
1.The above calculation tool designed for a standard 4-20 ma signal conversion.
2.You can convert out of range signal also with the above tool.
(Example: you can calculate for -10 % also and 110% as well)
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
DP Flow Transmitter Re-Ranging Calculation
Density Measurement using DP Transmitter for closed tank with wet leg
Convert Process Variable to Percentage
Conversion of Transmitter Output in Percentage to Process Variable
Density Measurement for Open Tank with Constant Level Application
  • hicham says:
    February 16, 2016 at 9:29 pm
    Formulas:
    (100%*16/100)+4 = 20ma
    (0%*16/100)+4 = 4ma
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Calculate Current (4-20ma) from Process variable PV
RTD Calculator : Calculate Resistance from Temperature
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Boiler Drum Level Transmitter Calibration
Level Measurement with Wet leg and Installed Below Tapping Point
Transmitter Current Conversion Tool
Convert Linear Percentage to Square root Percentage
Convert Linear mA to Square root mA
Closed-Tank-DP-Type-Level-Measurement-with-Dry-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Dry leg and Installed Below Tapping Point
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Dry-Leg
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Interface level Measurement
Interface Level Measurement using DP Transmitter
instrumentation-calculator
Instrumentation Calculator
RTD Calculator : Calculate Temperature from Resistance
Current to percentage conversion
Convert current (4-20mA) to Percentage (0-100%)
Analytical Instrumentation Engineering Projects
Top 100 Analytical Instrumentation Engineering Projects
Combining Independent Voltage Sources in Series
Sequential Operation of Output Bits using Two Push buttons
Beam-Detectors-Working-Principle-2
Beam Detectors Working Principle Animation
Multi Way Switches using PLC
Making Multi Way Switches using PLC
Cable Bending Radius
What is Cable Bending Radius? – Definition & Calculation
Top PLC Manufacturers
PLC Brands Software Information
Inductive Transducers Objective Questions
