Reading: Configuration of Profibus Network in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Configuration of Profibus Network in Siemens PLC
Last updated: March 4, 2021 12:21 pm
In this article, I will cover the configuration steps of the Profibus network using Siemens Simatic manager.
Profibus is a famous communication protocol founded by siemens provide a baud rate of 187.5 kb/sec. We can connect up to 64 devices on a single network.
Also Read: Principle of Profibus
When I/O devices are installed over long distances instead to lay a cable from the control room to field can become complex and increase installation cost too.
To mitigate complexity, we can mount a small local panel near to field devices. Now the local panel will be connected to the control room system cabinets. We have to use IM (Interface Module) which will provide communication from that panel to control room utilizing Profibus method. This is called remote I/O.
It recognizes by its purple color outer jacket.
Consider that We have to mount some digital and analog devices on remote location. Let’s follow the below steps to configure the Profibus network.
Step 1:
Open Simatic manager. Create a new project and select the type of the CPU.
Step 2:
Select and add Required module as located in the main control room. Please visit my previous article on how to create a new project.
Select CPU type which has a Profibus port on it as we are going to configure the Profibus network. In our case, I have chosen CPU 315-2DP.
For the practical purpose you can choose random I/O otherwise choose as per your physical I/O arrangement.
Simatic Hardware Configuration
Step 3:
To create a Profibus network double click on “DP” as shown in the below window.
Clicking on DP will open a new pop-up window as shown in the below window.
Step 4:
Here, “Networked selection is no”. To configure network click on “properties”.
Siemens Networked selection
Step 5:
Clicking on properties will open up the following window. Click on “New” to add network. Here default address is “2”. Leave as it is.
Profibus Interface Addresses
Step 6:
Clicking on new will pop up one more window. Change the name if you wish to. Click “ok” to add.
Profibus Network Settings
Step 7:
The network is added with default speed. Hit “ok” again to proceed.
Profibus Interface DP
Step 8:
Here, previously “NO” is turned to “Yes”. Hit “ok” to proceed.
Profibus Window in Siemens PLC
Step 9:
Now you can see that the Profibus network is added. Here on this network, you can add Drive, IM, etc. We have to add here remote I/O, so we will configure Interface Module.
Profibus DP Master System
Step 10:
To add the Interface module we have to select ET (Electronic terminal). To add, expand “PROFIBUS-DP” where you can find a variety of “ET-200”.
To select the “IM” expand the “ET-200” module and select the Interface Module as per model number we have in the hardware.
For the sake of our example, I will use ET-200S.
Profibus Interface Module
Step 11:
Here, expanding ET-200is will open IM 151-2. Add Analog and digital module as per model number located on the hardware.
ET 200 iS
Step 12:
Drag and drop IM 151-2 on the network which we have created earlier.
The following window will pop-up asking you for the address. To Add address have a look onto actual IM where you can find DIP switches. See which DIP switches are on and add them.
For example, if ON DIP switches are 2, 4, and 8. Now add them 2+4+8 = 14. So. An address which we have to add here is 14.
The maximum address you can add is “128”.
After adding address hit “ok” to proceed.
How to Configure Profibus in Siemens PLC
Step 13:
IM is added with the address which we had entered. Let’s add the I/O module.
Simatic 300 Profibus
Step 14:
Select IM to add modules. You can see below the window that I have added all the required modules installed in hardware as per the order number. We are done with Profibus Network.
Siemens Communication Settings
Author: Suhel Patel
  • Siemens S7 1200 PLC configuration
  • Password Protect HMI in TIA Portal
  • Upload Siemens PLC Program
  • Backup from Siemens S7-300
  • Temperature Alarms in TIA Portal
PLC Logic Functions
Industrial Networking and Wireless Interview Questions
RSLogix5000 PLC Program Backup procedure
What is Hot Standby in PLC?
  • segwabanyana Wetshootsile says:
    May 5, 2020 at 9:57 am
    Please send me steps on how configure Variable Speed Drive (VSD) to control the speed of a motor.
Siemens HMI Training – Using UDTs with Faceplates
Electrical Switches Principle & Types
XG5000 Example of Simple Conveyor Control PLC Program
PLC Program for 2 Push buttons to Control 1 Output
How to Connect a Solenoid Valve with PLC?
Five Types of PLC Programming languages
Difference between Compact PLC and Modular PLC
Pulse Generation using Timer in Siemens PLC
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
Relay Internal Parts
Relay Operation, Types, Symbols & Characteristics
Sequencer Output in PLC
PLC Sequencer Instruction with Example
Siemens Industrial Laptop (Simatic Field PG)
Connect to the Siemens S7 PLC
Codesys function block example
Create a User-Defined Function Block in Codesys
Sticker machine with weighing PLC logic
Product Sticker Machine with Weighing PLC Program
Electrical and Instrumentation Maintenance Test
Electrical and Instrumentation Test
Sensors and Transducers Objective Questions
PID Controller Graph - 3
PID Controllers Graphical Analysis
control of level in three cascaded Loops
Multiple Lags (orders)
Types of Industrial Level Sensors
Programmable Logic Controller (PLC) Questions and Answers – 1
Advances in Control System
Fuzzy Logic Control
