Reading: Comparison of Venturi and Orifice flow meter
Inst Tools > Blog > Flow Measurement > Comparison of Venturi and Orifice flow meter
In comparing the venturi meter with the orifice meter, both the cost of installation and the cost of operation must be considered.
Last updated: November 1, 2023 6:47 am
Flow Measurement
3 Min Read
The orifice plate can easily be changed to accommodate widely different flow rates, whereas the throat diameter of a venturi is fixed, so that its range of flow rates is circumscribed by the practical limits of Dp.
Compare Venturi and Orifice
Orifice Plate Sizing
Image: orifice Plate
The orifice meter has a large permanent loss of pressure because of the presence of eddies on the downstream side of the orifice-plate; the shape of the venturi meter prevents the formation of these eddies and greatly reduces the permanent loss.
The orifice is cheap and easy to install. The venturi meter is expensive, as it must be carefully proportioned and fabricated. A home made orifice is often entirely satisfactory, whereas a venturi meter is practically always purchased from an instrument dealer.
On the other hand, the head lost in the orifice for the same conditions as in the venturi is many times greater. The power lost is proportionally greater, and, when an orifice is inserted in a line carrying fluid continuously over long periods of time, the cost of the power may be out of all proportion to the saving in first cost. Orifices are therefore best used for testing purposes or other cases where the power lost is not a factor, as in steam lines.
Venturi Flow Meter Animation
Animation: venturi Flow Meter
However, in spite of considerations of power loss, orifices are widely used, partly because of their greater flexibility, because installing a new orifice plate with a different opening is a simpler matter. The venturi meter can not be so altered. Venturi meters are used only for permanent installations.
It should be noted that for a given pipe diameter and a given diameter of orifice opening or venturi throat, the reading of the venturi meter for a given velocity is to the reading of the orifice as (0.61/0.98)2, or 1:2.58. (i.e. orifice meter will show a higher manometer reading for a given velocity than the venturi meter).
  • Coriolis Mass Flow meter
  • Orifice Flow Meter Compensation
  • Basics of Flow measurement
  • Different Types of Flow Sensors
  • Dall Tube Flow Meter Theory
What is a Paddle Wheel Flow Meter?
Interferometer Principle
Is it Easy to Measure Natural Gas Flow and Volume?
What is a Vortex Flow Meter?
Oval Gear Flow Meters – Principle, Advantages, Animation
DP type Flow Transmitter Preventive Maintenance and Calibration
Change-of-Quantity Flow Measurement
Impulse Line – Purpose & Tapping Point Location
Turbine Flow Meters Troubleshooting
Overview of Positive Displacement Flow Meters
How does an Orifice Measures Flow?
Reasons to Calibrate Different Types of Flow Meters
Annubar flow principle
Different Types of Flow Elements
Multiphase Flow Meter Calibration Procedure
Flow Meter Hook Up
Flow Meter Installation Guidelines
Turbine Flow Meter Installation Procedure
DP-Flow-Transmitter-Re-Ranging-calculation
DP Flow Transmitter Re-Ranging Calculation
Troubleshooting DP type Transmitter Common Problems
Averaging Pitot Tube Working Principle
Fail-Close Valve
What is a Fail-Close Valve? – Advantages and Disadvantages
Immersion Electrical Heaters
Single and Three Phase Immersion Electrical Heaters Wiring Circuits
Erasable Programmable Read Only Memory Objective Questions
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Random Access Memory Objective Questions – Part 1
circuit-breaker-working-principle-animation
Circuit Breaker Working Principle Animation
Purpose of an Electrical Substation
What is a Substation? Purpose of an Electrical Substation
