Reading: Comparison of Level Meters – Level Measurement Instruments
Inst Tools > Blog > Level Measurement > Comparison of Level Meters – Level Measurement Instruments
The level meters or level transmitters come in a variety of types, each designed for specific applications and conditions.
Last updated: September 19, 2023 3:17 pm
Level Measurement
3 Min Read
Comparison of Level Meters - Level Measurement Instruments
Below is a comparison table outlining the key features, advantages, and disadvantages of commonly used types of level meters.
ParameterFloat OperatedCapacitiveUltrasonicRadar (Guided Wave)Radar (Non-Guided Wave)Differential PressureDisplacerOptical
Principle of OperationBuoyancyCapacitanceSound WavesElectromagnetic WavesElectromagnetic WavesHydrostatic PressureBuoyancyLight Refraction
Fluid CompatibilityLiquidsLiquidsLiquids, SolidsLiquids, Solids, SlurriesLiquids, Solids, SlurriesLiquids, SlurriesLiquidsLiquids
AccuracyModerateHighModerateHighHighModerateModerateHigh
RangeLimitedModerateModerateWideWideModerateModerateLimited
Temperature LimitsModerateModerateModerateHighHighHighHighHigh
Pressure LimitsModerateModerateLowHighHighHighHighModerate
CostLowModerateModerateHighHighModerateModerateHigh
Maintenance RequirementLowLowModerateLowLowHighModerateLow
Power RequirementNoneRequiredRequiredRequiredRequiredRequiredRequiredRequired
Response TimeFastFastSlowFastFastModerateFastFast
Ease of InstallationEasyModerateModerateModerateModerateModerate to DifficultModerateEasy
Safety AspectsGood for non-hazardousGoodLimited in flammableGood for hazardousGood for hazardousGood for hazardousGoodGood
Here’s a brief explanation of the terms used:
  • Principle of Operation: The underlying technology or physics on which the level meter operates.
  • Fluid Compatibility: Types of fluids that can be measured by the level meter.
  • Accuracy: The level of precision in measurement.
  • Range: The distance or level range over which the instrument can effectively measure.
  • Temperature Limits: The temperature range within which the instrument can operate safely and accurately.
  • Pressure Limits: The pressure range within which the instrument can operate safely and accurately.
  • Cost: The relative financial outlay required for purchase and installation.
  • Maintenance Requirement: The level of maintenance the equipment generally requires.
  • Power Requirement: Whether or not electrical power is required for operation.
  • Response Time: The speed at which the level meter provides a reading.
  • Ease of Installation: How straightforward it is to install the equipment.
  • Safety Aspects: Considerations about the level meter’s suitability for measuring in hazardous or extreme conditions.
  • Level Indicators Working Principle
  • Transparent & Reflex Level Gauge
  • Calculate Current 4-20 mA
  • Mechanical Level Indicators Principle
  • Instrumentation Impulse Lines
Calibration of Displacer Level Transmitter
How a Level Switch Works
Capacitive Tank Gauges
Level Instruments General Specifications
  • Scott Kim says:
    August 9, 2024 at 7:22 am
    Dear Sir,
    I’m very pleased to introduce our company ‘IS Technology(http://istec.co.kr)’ in South Korea. Founded in 1993, based on the ultrasonic and radar sensor technology accumulated over the past 30 years, it is now growing into a global professional company related to smart water management solutions. In particular, our brand ‘SONDAR’ is a specialized measurement sensor brand that focuses on making precise sensors in all processes from synthesizing piezoelectric materials, the basis of ultrasonic waves, to manufacturing finished sensors.
    The item we would like to introduce today is Smart Ultrasonic & Radar Level and Flow Meter which our company has recently upgraded its function dramatically. High durability and low power design are applied to compensate for the shortcomings of the existing level meter. It is a non-contact ultrasonic & radar water level meter with an integrated sensor and controller design. No 1. Water Management Platform Company which is leading the digitalization of the water industry based on 30 years of ultrasonic & radar sensor technology and 20 years of remote monitoring technology. With this differentiated technology, we strongly hope for strategic cooperation with you or your company.
    We are particularly interested in marketing cooperation targeting the global market, and we will respond positively with an open mind to any cooperation proposals from you. Thank you for reviewing our offer, and we look forward to your prompt reply.
    Sincerely yours,
    Scott Kim
How to Calculate mmWC Range of Level Transmitter with Examples?
Inductively Coupled Wire Guided Float Detectors
Effect of Temperature & Pressure on Level Measurement
Air Purge or Air Bubbler Level Measurement
Non Contact RADAR Level Transmitter Principle, Limitations, Design, Installation and Calibration
Remote Seal Transmitters Ranging Calculation
Level Measurement Terminology
Laser Level Measurement
Laser Level Measurement Principle
All About Instrumentation Impulse Lines
Root Cause Analysis of Differential Pressure Level Transmitter
Displacer Level Transmitter weight calibration
Displacer Level Transmitter Dry Calibration with Weights
Types of Tank Gauging Level Measurement Systems
Tank Gauging Measurement
Purpose of Tank Gauging Level Measurement
Level Gauge Working Animation
Sight Glass Level Measurement Principle
Bubble Tube Level measurement
Bubble Tube Level Measurement Principle
What is a Thermopile ?
HVAC Principle and Theory
Recommendations to HVAC Engineers
How to Upload PLC Program in Siemens PLC if Upload Icon is Disabled
Upload Option Disabled in Siemens PLC
PLC Examples for calling functions in SCL
Functions of Pressure Detectors
PCB Making Machine
Beyond FR-4: Exploring Novel Materials for PCB Fabrication
DC Machine Quiz
The Top Services a Great B2B Agency Offers
