Reading: Compare Two Offline PLC Projects
Inst Tools > Blog > PLC Tutorials > Compare Two Offline PLC Projects
In this article, I will explain to you about the comparison of two different offline PLC projects using Siemens TIA PORTAL.
Last updated: March 4, 2021 11:22 am
3 Min Read
In this article, I will explain to you about the comparison of two different offline projects using Siemens TIA PORTAL.
When your PC has two different projects and if you wish to check both projects are the same or different ones then you can use a compare tool to identify the differences between the projects if any.
Do follow the below steps to know about the comparison of two offline projects.
Step 1:
Open TIA PORTAL. Open any existing program or create a new one.
Save the project and again save it as a different name to compare to offline projects.
Here, I will add one of the valve control programs which I want to compare.
So, this is the first offline project window which you can see below.
How to Compare Two Offline Projects
Step 2:
To compare add the second project and click on the “view” icon as shown in the below window.
Now, do a checkmark in front of “reference project”.
TIA Portal Compare Two Offline Projects
Step 3:
The following reference window will be added to the project tree.
PLC Projects Comparison
Step 4:
Now, click on the below folder to add the second project.
Siemens Simatic Offline Projects Comparison
Step 5:
The following pop-up will open up. Now, select the second project which you have saved.
In our case, I have created a project with a name “valve control”
The project which already open has a name “valve control123” is given which you can see in the below window.
Hit “open” to proceed.
Tia Portal Open Reference Project
Step 6:
As you can see in the below window the second project is added.
Siemens PLC Programs Compare
Step 7:
Now, do right click as shown in the below window and choose “compare” and select “offline-offline”.
Offline and Offline PLC Logics
Step 8:
The following window will open up.
Siemens Compare Editor Offline
Step 9:
Now drag and drop the second project.
Tia Portal Reference Projects
Step 10:
As you can see, the second project is added to the blank space.
You can also see the green radio buttons confirming that both projects are the same. If any conflicts are there is indicated in a different color. Which you can see in my article on comparing online and offline projects.
Then you can do a detailed comparison and check the reason for the conflicts.
PLC offline data of a project are compared
Author: Suhel Patel
  • Motor Direction Control
  • Siemens MMC Card
  • Siemens PCS 7 DCS
  • Electrical Circuit Schematic
  • Programmable Logic Controller
Siemens TIA Portal: Motor Forward Reverse PLC Logic
PUT Command in Siemens PLC – TIA Portal Basics
Establishing a Modbus Driver for SCADA Indusoft Web Studio
Sequential PLC Programming for the Pneumatic Valves
Communication between Wincc and Tia Portal
Allen Bradley Powerflex VFD
SCADA Software and their Comparison
Quiz: Identifying I/O Examples in PLC Systems
Inside the PLC Control Panel: How Much Do You Know?
80+ PLC MCQ Questions
PLC Program for Motor Starter
Top 100+ SCADA Questions
Laws of Boolean Algebra using Ladder Logic
Cybersecurity in PLC
Single-Acting Cylinder Control Operation using Proximity Sensor
Single-Acting Cylinder Control using Proximity Sensor
Exhaust Fan Control
Exhaust Fan Control: Example of PLC Timer Programming
Scaling in PLC
PLC Ladder Logic for Sensor Scaling with Offset
Top PLC Manufacturers
Modbus in Industrial Networks
What is a Wet Contact in PLC
What is a Wet Contact? – Basics of PLC Wiring
Oxygen Analyzer Principle
Oxygen Analyzer Working Principle
Tank car bonding at siding
Electrical Static Grounding Techniques
Limit Switch Working
Limit Switch Animation
Why CT Secondary Should Never Be Kept Open?
Squirrel Cage Induction Motor Synchronous View
Squirrel Cage Induction Motor Animation
Vehicle Electrical Batteries upgrade
Upgrading the Electrical System in an Automobile
Functional Block Diagram in PLC for Oil and Water Process
H & B Gas Analyzer Principle and Calibration Procedure
