Reading: CODESYS HMI Interface
Inst Tools > Blog > PLC Tutorials > CODESYS HMI Interface
Learn how to design a standard CODESYS HMI interface and link it with the PLC program to learn the basics first.
Last updated: May 7, 2024 12:37 pm
Codesys is a platform that has been developed for industrial automation devices and has its own set of frameworks for graphics, screen layout, blocks, instructions, syntax, and other elements.
Any PLC manufacturer that uses Codesys can find this common layout and rules in other PLCs too that use Codesys. Nowadays, devices have come in Codesys which offer PLC programming along with HMI screens in the same hardware and platform. One such device is GOC43 of Mitsubishi Electric, which is a PLC cum HMI controller.
In this post, we will learn how to design a standard Codesys PLC program and link it internally with Codesys HMI visualizations by using this device as a reference. We will create a simple understandable program and not go deeper into the topic by just learning the basics first.
All the Codesys platforms have the following languages supported for PLC programming – continuous flow chart, function block diagram, ladder logic, sequential function chart, and instruction list.
You are provided with two options: create a section (program) or create a user-defined library (function block). It is referred to as POU (program organization unit). That means if you have created 10 sections of the program and function block, it means you have created 10 POU’s in the program.
A variable can be defined in two scopes – local or global, as shown in the figure below. In the section we created, if we define a variable named test in the section itself, then it can be used locally in that section only.
Inversely, if we define this variable in GVL (global variable list), then it can be used in any section of the whole program.
CODESYS HMI Visualization
Now, suppose we define the variables locally in our example. Refer to the below image.
As you can see, the start variable has not been given a memory address, whereas the number variable has been given the memory address as %MW2. This means that the number variable can be accessed by an external device like HMI or other master controllers through this address.
Accordingly, you need to define variables as per your requirement, by either giving them an address or not. You can take the blocks and instructions from the right-hand side toolbox as shown.
CODESYS HMI PLC Implementation
Then, you need to add the section we created in the task configuration as shown below with the black box. This will allow the PLC CPU to execute that logic. Otherwise, it will not be executed in the processor.
Creating an HMI in CODESYS
Now, we head on to the graphics part. As seen in the figure below, you have to add a visualization object, just like you added a POU object for PLC programming. This will create a screen. There, you can place the objects as per your requirements.
As you can see in the below image, on the right-hand side, it shows the properties of a rectangle object that I have placed. There, you can directly link the variables that you defined in the PLC program – like text variables, color variables, and state variables and also configure input action in input configuration.
HMI with CODESYS
So, just create variables with any name in the PLC program and directly link in the objects wherever required.
In this way, we saw how to design a sample project involving PLC and HMI programming using Codesys software.
  • Download Free CODESYS Software
  • Learn about SCADA and HMI Systems
  • Difference between PLC and HMI Systems
  • Create an Application in HMI using the Tia Portal
  • What is CODESYS? Why Do You Need to Learn It?
PLC Program for Water filling and Discharging Process
3 to 8 Line Decoder PLC Ladder Diagram
FIFO Instruction in Allen Bradley PLC Programming
What is Contextual HMI? – HMI Screens on a Mobile or Tablet
Ladder Logic Example with Timers
  • Arvin Mistry says:
    June 20, 2024 at 2:05 am
    Example must be completed in the same , Example tuterial, rather waiting for next vedio.
Global Acknowledgment Instruction in Safety PLC
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
Software Troubleshooting Errors and Faults in Siemens PLC
PLC Analog Input Scaling
How to Run Multiple Motors with a Single VFD?
Difference between PLC and Computers
PLC Karnaugh maps
How to Simplify PLC Coding Using Karnaugh Maps?
Structured Text PLC Example for Motor Interlocking and Control
PLC Program Paint Spraying
PLC Program for Paint Spraying
PLC Memory Mapping
PLC Memory Mapping and I/O addressing
memory types in siemens plc
Memory Structure of Siemens PLC
PID block from the PLC library
How to Configure PID Controller in Various Schneider PLCs?
Introduction to PLC
Introduction to PLC – Advantages of PLC
PLC Tag Naming Conventions
Electrical Engineers Basics
Basic Electrical Engineering Questions & Answers
Lift check valves
What is Lift Check Valve ?
Boolean Algebra to PLC Logic
From Boolean Algebra to PLC Logic
Sugar Industry Logics
Mill Interlocks in the Sugar Industry
Transformer Coil Polarity
Circuit Measurement Objective Questions
Electrical and Electronics Circuit Measurement Objective Questions
