Reading: Classification of Flow Measurement Techniques
Inst Tools > Blog > Flow Measurement > Classification of Flow Measurement Techniques
There are different Classifications of Flow Measurement Techniques for measuring the flow rate and total flow. Each has specific characteristics.
Last updated: October 31, 2023 3:10 pm
Flow Measurement
2 Min Read
There are various different methods for measuring the flow rate and the total flow. Each method has its own specific characteristics which are directed toward individual installation requirements.
In the following, the most important measuring principles are mentioned below.
In the figure above for the measurement in closed piping a distinction is made between total flow meters (totalizers) and flow rate meters (flow meters). So, what are the characteristics of these two variants?
Total flow meters, usually volume totalizers, are devices filled with a defined volume which is then measured and integrated to determine the total flow volume. Direct volume totalizers have movable measuring chambers with a defined volume (comparable to a line of buckets).
Indirect volume totalizers, on the contrary, do not have closed measuring chambers, but work either mechanically using rotary vanes and transporting partial volumes between the vanes, or electrically with pulses that are proportional to the volume.
Flow meters also use the direct method for measured value acquisition. They measure either the flow velocity or the kinetic energy of the flow.
Source: ABB
  • Flow Measurement Questions
  • Important Factors in Flow
  • Magnetic Flow Meter Theory
  • What is the Coriolis flow meter?
  • Ultrasonic Flow Meter Operation
Principle of Flow Switch
Types of Vortex Flow Meter Sensors
Why Flow is Directly Proportional to the Square Root of DP?
Venturi Flow Meter – Working Principle, Advantages, Animation
Step by Step Guide for Gas Flow Meter Calibration
  • Ranjitha says:
    November 29, 2016 at 3:35 pm
    Why electromagnetic transducers are used in flow measurements?
Comparison of Venturi and Orifice flow meter
What is a Velocity-based Flow Meter?
Is it Easy to Measure Natural Gas Flow and Volume?
Transit Time Flow Meter Principle
Different Flow Measurement Technologies
Piston Flow Meters Working Principle with Animation
Mass Flow Meters
How Coriolis Mass Flow Meter Measure Density?
Square-Root extraction in DCS or Transmitter
Square-Root in DCS or Flow Transmitter?
Oval Gear Flow Meter Principle
Oval Gear Flow Meters – Principle, Advantages, Animation
Turbine Flow Meter
All About Turbine Meters
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
Rotameter
What is a Variable Area Flow Meter?
Lobed Impeller Flow Meters Working Principle
Electro Magnetic Flow Meter Animation
Turbine Flow meter coefficient
Turbine Flow Meter Coefficient and Scaling Factor
Ladder Logic Programming Examples
Transformer Coil Polarity
Pneumatic Load Cell Principle
DP transmitter Elevated 10 Feet above the Vessel
PLC Program for Controlling Sequence of Conveyors with Interlocking
Control Valve Air to Open type
Control Valve Installation, Maintenance, Disassembly & Reassembly
Heavy Equipment Transport
4 Tips For Shipping Large Construction Equipment
Relation Control
Relation Control System
