Reading: Basics for CAN Bus Protocol – Controller Area Network
Inst Tools > Blog > Communication > Basics for CAN Bus Protocol – Controller Area Network
A controller area network is ideally suited to the many high-level industrial protocols. Learn the basics of CAN bus protocol.
Last updated: January 24, 2023 11:46 am
Hussien Ghareb
Communication Control Systems
6 Min Read
A controller area network (CAN) is ideally suited to the many high-level industrial protocols. Its cost, performance, and upgradeability provide tremendous flexibility in system design.
CAN Bus ProtocolCAN Protocol with the OSI ModelFocus Points to Establish a CAN NetworkRelation Between Speed & Cable Distance
This article briefly introduces the CAN bus operating principles, the implementation of a primary CAN bus network, and how to troubleshoot this network.
CAN Bus Protocol
The CAN bus is a multi-master, message broadcast system that specifies a maximum signaling rate of 1M bit per second (bps).
Unlike a traditional network such as USB or Ethernet, CAN does not send large blocks of data point-to-point from node A to node B under the supervision of a central bus master.
In a CAN network, many short messages like temperature or RPM are broadcast to the entire network, which allows for data consistency in every node of the system.
CAN is an International Standardization Organization (ISO) defined serial communications bus originally developed for the automotive industry to replace the complex wiring harness with a two-wire bus.
The CAN communications protocol, ISO 11898, describes how information is passed between devices on a network and conforms to the Open Systems Interconnection (OSI) model that is defined in terms of layers.
The actual communication between devices connected by the physical medium is defined by the physical layer of the model. The ISO 11898 architecture defines the lowest two layers of the seven-layer OSI/ISO model as the data-link layer and physical layer. As shown in Fig. (1)
Figure 1
The application layer establishes the communication link to an upper-level application-specific protocol such as the vendor-independent CAN open protocol. This protocol is supported by the international users and manufacturers group, CAN in Automation (CIA).
There are many similar emerging protocols dedicated to particular applications like industrial automation or aviation.
Examples of industry-standard CAN-based protocols are KVASER’s the CAN Kingdom, Allen-Bradley’s Device Net, and Honeywell’s Smart Distributed System (SDS).
  • CAN protocol define the Data Link Layer and part of the Physical Layer in the OSI model.
  • Each CAN unit connected to the bus can be called a node. All CAN units are connected to a bus terminated at each end with 120 Ω resistors to form a network.
  • The CAN bus consists of two wires (CAN_H & CAN_L lines).
  • The CAN controller determines the bus level based on the difference in the power level on both wires.
  • Bus levels are divided into dominant and recessive levels, which must be one of them, the sender sends the message to the receiver by making a change at the bus level.
  • In the dominant state, the voltage of CAN_H is about 3.5V and the voltage of CAN_L is about 1.5V. In the recessive state, the voltage of both lines is around 2.5V.
  • The signal is differential which is why CAN derives its robust noise immunity and fault tolerance. A balanced differential signal reduces noise coupling and allows for high signaling rates over twisted-pair cable. The current in each signal line is equal but in the opposite direction and resulting in a field-canceling effect that is key to low noise emissions. The use of balanced differential receivers and twisted-pair cabling enhances the common-mode rejection and high noise immunity of a CAN bus.
Figure 2
The CAN bus is a bus that connects multiple units at the same time. There is theoretically no limit to the total number of units that can be connected. In practice, however, the number of units that can be connected is limited by the time delay on the bus and the electrical load.
Reduce the speed of communication, increase the number of units that can be connected, and increase the speed of communication, the number of units that can be connected decreases.
The communication distance is inversely related to the communication speed, and the farther the communication distance, the smaller the communication speed. The longer distance can be 1km or more, but the speed is less than 40kps.
Resources
  • Introduction to the Controller Area Network (CAN) by Texas Instruments.
  • instructables.com/A-Simple-Tutorial-for-CANBUS
  • 4-20 mA Transmitter Wiring
  • Electrical Earthing Calculations
  • Why 24 Volts DC Power Supply?
  • Interposing Relay Panel Wiring
  • SCADA Software and Comparison
Difference Between PNP and NPN Sensors
Basics of Foundation Fieldbus
Process Interlocks and Trips
4–20 mA Process Control Loops
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
Ziegler-Nichols Open-Loop Method
PID Controller Gains Effect on Manipulated Variable
Basics of Trips, Interlocks, Permissives & Sequences
DCS versus PLC Architecture
Advantages and Disadvantages of Network Topologies
Temperature Controller Problem
What is Alarm Prioritization? – Types of Alarms
Alarm Management System
What is Alarm Management System ?
Cyber Security Multiple Choice Questions and Answers
Unmanaged Switch
Managed Switch vs Unmanaged Switch
Control Valve Direction of Control Action
PID Controller Action : Directing Acting & Reverse Acting
Fieldbus Control
Fieldbus Control
FF instrument
H1 FF Device Configuration and Commissioning
Feed forward example
What is Feedforward Control ?
Multiple Pumps Control using PLC
PID Controller Graph - 3
PID Controllers Graphical Analysis
ON OFF Valve Parts
ON OFF Valve Preventive Maintenance and Testing Procedure
Industrial Instrumentation Questions & Answers
Losses of Transformer
Solenoid-controlled Valve Problem
Augmented Reality and Virtual Reality in Industrial Automation
Barrier & Sensor Connection with NAMUR
Why we use NAMUR Output Sensor?
