Reading: Basic Requirements of Control Valves Sizing
Inst Tools > Blog > Control Valves > Basic Requirements of Control Valves Sizing
Last updated: March 21, 2019 11:23 pm
Control Valves Instrumentation Design
2 Comments
A control valve is a power operated device capable of modulating  flow at varying degrees between minimal flow and full capacity in response to a signal from the controlling system. Control valves may be broadly classified by their function as “on-off” type or “flow regulating” type.
Control Valves SizingTIPS AND TRICKS
A control  valve  is comprised  of an  actuator  mechanism  that  is capable  of changing  the position of flow controlling element in the valve. The valve modulates flow through movement of a valve plug in relation  to the port(s)  located  within  the valve body. The valve  plug is attached to a valve stem, which, in turn, is connected to the actuator.
The actuator, which can be pneumatically  or electrically operated, directs the movement of the stem as dictated by the external  control  device.  The actuator  responds  to an external  signal which usually comes from a controller. The controller and valve together form a basic control loop.
There are many types of valves available, each having their advantages and limitations.
The basic requirements  and selection depend on their ability to perform specific functions such as:
  1. Ability to throttle or control the rate of flow;
  2. Lack of turbulence or resistance to flow when fully open – turbulence reduces head pressure;
  3. Quick opening and closing mechanism – rapid response is many times needed in an emergency or for safety;
  4. Tight shut off – prevents leaks against high pressure;
  5. Ability to allow flow in one direction only – prevents return;
  6. Opening at a preset pressure – procedure control to prevent equipment damage; and
  7. Ability to handle abrasive fluids – hardened material prevents rapid wear.
TIPS AND TRICKS
Take the following tips into consideration when choosing a valve.
  1. Choose a valve that will pass the maximum flow when about 90% open.
  1. Choose a valve that will pass the minimum flow when about 10% open.
  1. Choose a valve that will pass the normal flow when about 60-70% open.
  1. Size control valves to absorb about 1/3rd of the total system pressure drop.
  1. Control valves  should  not  be  less  than  half  the  pipe  size.  Normally  the  valves exclusively envisaged for shut-off service shall be line size. Alternatively,  they could be sized as control valves.
  1. In the case of lines with a diameter of up to 1″ the valve size shall normally equal that of the line. In the case of lines with a diameter larger than 1″ the valve size shall not be less than 1″.
  1. Valves shall generally have flanged connections  as per rating envisaged in the line specification  with the exception  of valves  with a nominal  diameter  smaller  than or equal to 1½” which shall have a minimum rating of 300 ANSI.
  1. If you are dealing with a corrosive fluid, choose the valve body and trim material to match the pump casing and impeller.
  1. Velocity is the key to handling abrasive materials. Keep line velocity of about 10 ft/s for  clean  liquid.  If you  have  a fluid  that  is abrasive,  keep  the  velocity  as  low  as possible, without having the particles drop out of suspension. When dealing with high pressure drop situations try always to keep the velocities below 0.3 mach on the inlet pipe, valve body, and outlet pipe.
  1. Always sense pressure  where  you  want  to  control  it.  Many  control  valves  and pressure  regulators  do  not  function  properly  simply  because  they  are  sensing pressure at one point and being asked to control it somewhere else.
  1. If you use a transducer in a control loop, specify a positioner on the valve. Otherwise the transducer will rob the actuator of available thrust, and the valve will leak when it is supposed to shut off.
  1. In cavitating fluids “be sure to allow a straight run of downstream pipe after the valve – even when the control valve has cavitation trim in it”. If there is a pipe “T” or elbow immediately downstream, the flow will choke out and back up into the valve.
  1. Remember that control  valves  only  do what  you  tell them  to. Many  control  valve problems turn out to be a problem somewhere else.
Articles You May Like :
Actuator Fail Safe Mode
Control Valve Animation
Basics of Globe Valves
Trip Valve Principle
Valves Chemical Problems
Instrument Numbering Philosophy
Choke Valve Hydro Testing Procedure
Difference between Blowdown Valve (BDV) and Shutdown Valve (SDV) ?
Basics of Control Valves
Interview Questions on Control Valves
2 Comments
  • karim says:
    October 22, 2016 at 5:58 pm
    Hi sir,
    first thank you this useful website and also the app.
    Could you please explain more the tip No 7?
    thanks
  • Virendra Kumar says:
    May 11, 2018 at 9:20 am
    Thanks sir
What’s the problem with shock and vibration ?
Self Actuated Pressure Control Valve Functional Testing
Electro Pneumatic Valve Positioner Schematic & Principle
How Needle Valve Works ?
Control Valve Passing Problem after Overhauling Job
Concept of Steam Conditioning Valves
Instrument Process Datasheet (IPDS)
sinking-and-sourcing-digital-output-modules
PLC Digital Signals Wiring Techniques
Selecting A Pneumatic Manifold
How to Select a Pneumatic Manifold
Purpose of Float Valve
What is a Float Control Valve? Types, Advantages, Disadvantages
Instrumentation Books Free Download
Control Valve Parts
Basic Parts of Control Valves
Solenoid Valve Functional Testing
Cable Schedule
What is Cable Schedule and Junction Box Schedule?
Special Control Valves
Electrical Motor Failures
Most General Reasons for the Electrical Motor Failures
pi filter Operation
pi filter Operation
Cutaway View of Circuit Breaker
Low Voltage Air Circuit Breaker Principle
Yokogawa differential pressure transmitter
Basics of Differential Pressure Transmitters
Control Valve Actuator Parts
Reversing Control Valve Actuator Fail Safe Mode
Voltage Polarities
Voltage Polarity and Current Direction
Observer Systems
Use of line reactors
