Reading: Applying Kirchhoff’s Current Law
Inst Tools > Blog > Electrical Theory > Applying Kirchhoff’s Current Law
Last updated: July 23, 2018 4:27 pm
Electrical Theory
3 Min Read
Kirchhoff’s second law is called his current law and states: “At any junction point in a circuit, the current arriving is equal to the current leaving.” Thus, if 15 amperes of current arrives at a junction that has two paths leading away from it, 15 amperes will divide among the two branches, but a total of 15 amperes must leave the junction.
We are already familiar with Kirchhoff’s current law from parallel circuits, that is, the sum of the branch currents is equal to the total current entering the branches, as well as the total current leaving the branches (Figure 35).
Illustration of Kirchhoff’s Current Law
Figure 35 Illustration of Kirchhoff’s Current Law
In equation form, Kirchhoff’s current law may be expressed:
Iin – Iout  = 0
Iin = Iout
Normally Kirchhoff’s current law is not used by itself, but with the voltage law, in solving a problem.
Example:
Find I2 in the circuit shown in Figure 36 using Kirchhoff’s voltage and current laws.
Current LawFigure 36 Using the Current Law
Solution:
First, apply Kirchhoff’s voltage law to both loops.
Loop ABCDEF
∑ IR = ∑ E source
2 Itotal + 6I1 = 6
Loop ABGHEF
∑ IR = ∑ E source
2 Itotal + 3I2 = 6
Since Kirchhoff’a current law states Itotal =I1 +I2 , substitute (I1 +I2 ) in the place of Itotal in both loop equations and simplify.
Loop ABCDEF
2 (I1+ I2) +6 I1 = 6
2 I1+2 I2+6 I1= 6
8I1 +2I2= 6
Loop ABGHEF
2 (I1+ I2) +3 I2 = 6
2 I1+2 I2+3I2= 6
2I1 +5I2= 6
We now have two equations and two unknowns and must eliminate I1 to find I2 .
One way is to multiply Loop ABGHEF equation by four, and subtract Loop ABCDEF equation from the result.
Multiply by 4:
4 (2I1 +5I2 = 6 )
8I1 +20I2 + 24
Subtract :
8I1 +20I2 = 24
-(8I1 +2I2 = 6)
18I2 = 18
Now we have an equation with only I2 , which is the current we are looking for.
18I2 = 18
I2 = 18/18 = 1 amp
This circuit could have been solved simply by using Ohm’s Law, but we used Kirchhoff’s Laws to show the techniques used in solving complex circuits when Ohm’s Law cannot be used.
Kirchhoff’s Laws
Calculate Power in Series RCL Circuit
Transformer Efficiency
Power Factor
Voltage Divider
Voltage Polarity and Current Direction
Electro-Dynamo Meter Movement
Series and Parallel Capacitors
Battery Operation : Series and Parallel
DC Motor Connections
Starting a Synchronous Motor
Calculate Power in Parallel RCL Circuit
Impedance in RL Circuits
3 Phase Balanced Loads
Power in Balanced 3 Phase Loads
Electric Open Circuit
Series Open Circuit Faults
Left-Hand Rule for Generators
Starting of DC Motors
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
Half-Wave Rectifier Circuit
Transformer voltage and turns ratio
Transformer Voltage Ratio
Voltage Drop in a Series Circuit
Series Resistance
Electric Short Circuit
Electric Circuit : Open & Short Circuits
Electromagnetic Field MCQ
PLC Training Course
#17 PLC Best Practices – Log PLC Uptime and Trend it on HMI
Precision Instruments Interview Questions
Pressure Transmitter Impulse Lines Heat Trace
Pressure Transmitters Heat-traced impulse lines
Flip Flops Objective Questions – Part 1
Transmitter Detailed Specifications
Transmitter Range and Sensor Limits
Transmitter Minimum Span, Accuracy & Turndown
Servo Valve
Proportional Valve and Servo Valves
