Reading: Air Compressor Control Circuit Problem
Inst Tools > Blog > Practical Questions > Air Compressor Control Circuit Problem
The air compressor control circuit has a problem and unable to start even when the air pressure is zero PSI.
Last updated: October 23, 2020 11:20 am
Practical Questions
3 Min Read
This air compressor control circuit has a problem. The air compressor refuses to start even when the air pressure is zero PSI.
Air Compressor Control Circuit has a Problem
A technician begins diagnosing the circuit, following the steps shown (in order):
Test 1: Measured 120 VAC between points A and C, with “Hand/Off/Auto” switch in the “Auto” position.
Test 2: Measured 120 VAC between points A and D, with “Hand/Off/Auto” switch in “Auto” position.
Test 3: Measured 0 VAC between points E and C, with “Hand/Off/Auto” switch in “Auto” position.
Test 4: Jumpered points A and B, with “Hand/Off/Auto” switch in “Auto” position. The motor did not start.
Identify any useful information about the nature or location of the fault derived from the results of each test, in order of the tests performed. If the test is not useful (i.e. provides no new information), mark it as such.
Assuming there is only one fault in the circuit, identify the location and nature of the fault as precisely as you can from the test results shown above.
Answer:
Test 1: Measured 120 VAC between points A and C, with “Hand/Off/Auto” switch in the “Auto” position. Proves there is 120 VAC control power available, that the fuse is good, and that the Hand/Off/Auto switch is passing power through to point A.
Test 2: Measured 120 VAC between points A and D, with “Hand/Off/Auto” switch in “Auto” position. Proves there is an “open” fault somewhere between those points, in one of the two switches, and that we do not have any other “open” faults in the contactor coil circuit.
Test 3: Measured 0 VAC between points E and C, with “Hand/Off/Auto” switch in “Auto” position. This is an unnecessary test, as we already know there is continuity through the overload contact.
Test 4: Jumpered points A and B, with “Hand/Off/Auto” switch in “Auto” position. The motor did not start. Combined with the results of previous tests, this test proves the “open” fault must lie between points B and D: namely the PSH.
The fault is an “open” high pressure switch (PSH), or in the wires connecting the PSH to points B and D.
  • Compressor Seal Oil System
  • PLC Compressor Logic
  • Instrument Air Compressor
  • Liquid Level Switch Control
  • PLC Water Level Control Logic
Credits: Tony R. Kuphaldt
Distillation Tower Displacer Level Instrument Check
Baffle Nozzle Assembly Sensitive Mechanism
Heat Exchanger Differential Pressure Transmitter
Questions on Dip Tube Type Level System
Pneumatic Relay Questions
Calculate the Magnitude of Hydrostatic Pressure
Identify Instrumentation Terms in Water Supply System
Something is Wrong with Strain Gauge Bridge Circuit
Calculate Hydraulic System Fluid Pressure
Programmable Logic Controller (PLC) Questions and Answers – 12
Signal Strength of Guided-wave Radar Level Instrument
Three-valve Manifold on Remote Seal DP Transmitter
Motion-Balance and Force-Balance Instruments
Simple High Level Indicator Circuit
compressor emergency shutdown system
Solenoid Valves Questions & Answers – 2
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
PLC program pushbutton switches
Analytical Control System of Heat Exchanger Questions
Calculate the amount of voltage at Thermocouple
Calculate the Voltage across Voltmeters of Thermocouple
PLC Program for Valves
PLC Pump Permissive Interlocks
Stilling well in liquid level measurement
Stilling Well in Interface Level Measurement System
Span of Pressure Gauge
How to Decrease Span of Pressure Gauge?
Electro Magnetic Flow Meter Animation
Erratic Radar Level Gauges
Erratic Radar Level Gauges Delays a Refinery Commissioning
Temperature Coefficient of Resistance
Temperature Coefficient of Resistance (α)
Diodes Voltage Quadrupler
Open Tank DP Level Measurement
DP Level Measurement Problems
Left-Hand Rule for Generators
Starting of DC Motors
PLC Example on Manufacturing Line Assembly
