Reading: Pressure Transmitter Calibration Procedure
Inst Tools > Blog > Calibration > Pressure Transmitter Calibration Procedure
Last updated: May 30, 2019 3:21 pm
Calibration Pressure Measurement
3 Min Read
This article provides step-by-step Procedure for Pressure Transmitter Calibration and Ranging, LRV and URV configuration of transmitter.
Pressure Transmitter Details :
  • Rosemount Make, 3051 series
  • 3051T- Guage & absolute pressure (models) 0.3 to 10000psi, 10.3 mbar to 689 bar
  • 3051C, DP guage & absolute (models) 0.1 to H2o to 4000psi, 0.25 mbar to 276 bar
  • Power supply range is 12VDC to 32VDC.
Main Steps to be Followed :
First step to be followed is proper permit should be taken and ensure the interlocks should be by passed as well as MOS (Maintenance override to be put ON condition in DCS) for the particular tag.
Use Tool box meeting & proper PPE’S .
Required tools and suitable fittings (Such as connector and union) for calibration.
Multimeter, HART communicator, Calibrator ( Pressure range should be greater than the transmitter)
For higher range use hydraulic pressure calibrators and for low ranges use low range calibrator.
  1. First isolate the main process isolation valve.
  2. De-pressurize the pressure transmitter by opening the vent valve
  3. Isolate the manifold valve and open the vent plug.
  4. Fix proper instrument fitting ( for eg:1/4”npt fitting)
  5. Connect the calibrator fitting in to the vent plug entry of manifold valve.
  6. The vent valve should be opened.
  7. The HART communicator cable should be placed as per transmitter wiring diagram.
  8. Apply pressure as per the range given in the transmitter or check with the HART communicator.
  9. Check the transmitter reading by applying pressure for 25%, 50%, 75%, and span range.
  10. If the transmitter needs to be calibrated use the HART communicator for calibration purpose.
  11. Zero & span trims can be done by using HART communicator.
  12. After calibration checking remove the pressure calibrator from the transmitter and flush the line.
  13. So that hydraulic oil or water will not be inside the transmitter.
  14. Close the vent plug.
  15. Isolate the vent valve and open the main isolation valve.
  16. Open the manifold isolation valve slowly, if u open fast sudden pressure may damage the transmitter diaphragm.
  17. After completion of the calibration ensure the transmitter is reading showing properly.
  18. Then enter the reading in calibration  report format.
  19. Check the reading in DCS also.
  20. Close the work permit from field operator and shift Engineer.
Articles You May Like :
Pressure Transmitter Manifolds
Differential Pressure Transmitters
Displacer Level Transmitter Calibration
4–20 mA Process Control Loops
HART Communication Guide
How much Pressure applied to U-tube Water Manometer?
Step by Step Guide for Gas Flow Meter Calibration
Calibration of Measuring Instruments – Significance, Costs & Risks
Pressure Gauge Pulsation Damping
How Capacitive Pressure Sensor Works ?
How to Calibrate the Eddy Current Conductivity Meter?
Diaphragms
Types of Pressure Measuring Scales
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Selection of Industrial Temperature Calibrator
Pressure Gauge Calibration Procedure
Specific Conductance Calibration Procedure
Stability and Uniformity of Temperature Bath
Pressure Gauge Maintenance and Troubleshooting
Pressure Gauges with Zero Adjustment
Pressure Gauges Zero Adjustment
Temperature-gauge-calibration
Temperature Sensor calibration procedure
Pressure Safety Valve Leak Test Procedure
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Infrared Temperature Calibrators
Different Types of Temperature Calibrators
Motor Operated Valve Functional Testing
Closed-tank-DP-Level-Transmitter-with-wet-leg-Zero-elevation-Calibration
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Calibration of Pyrometers using Black Body
Wiring-Connection-from-PLC-to-Solenoid-Valves
How to Connect a Solenoid Valve with PLC?
How to Troubleshoot a PLC System
How to Troubleshoot a PLC System?
PLC Programming Example on Timers Function Block
FactoryTalk View Studio Site Edition Pop-Up Confirm Action
How to Automatically Close Pop-up in FactoryTalk View Studio?
What is Cloud Computing
What is Cloud Computing? Types of Cloud Services, Components
Single Port Globe Valve
How Sliding Stem Valves Work ?
CAN Protocol with the OSI Model
Basics for CAN Bus Protocol – Controller Area Network
