Reading: What is a Hydraulic Actuator ?
Inst Tools > Blog > Control Valves > What is a Hydraulic Actuator ?
Last updated: March 21, 2019 4:48 pm
Control Valves
2 Comments
Pneumatic actuators are normally used to control processes requiring quick and accurate response, as they do not require a large amount of motive force.
Hydraulic ActuatorAdvantages of Hydraulic ActuatorsDisadvantages of Hydraulic Actuators
However, when a large amount of force is required to operate a valve (for example, the main steam system valves), hydraulic actuators are normally used.
Although hydraulic actuators come in many designs, piston types are most common.
Also Read : What is a Pneumatic Actuator ?
A typical piston-type hydraulic actuator is shown in Below Figure. It consists of a cylinder, piston, spring, hydraulic supply and return line, and stem.
The piston slides vertically inside the cylinder and separates the cylinder into two chambers. The upper chamber contains the spring and the lower chamber contains hydraulic oil.
Hydraulic Actuator
Hydraulic Actuator Principle
The hydraulic supply and return line is connected to the lower chamber and allows hydraulic fluid to flow to and from the lower chamber of the actuator. The stem transmits the motion of the piston to a valve.
Initially, with no hydraulic fluid pressure, the spring force holds the valve in the closed position. As fluid enters the lower chamber, pressure in the chamber increases.
This pressure results in a force on the bottom of the piston opposite to the force caused by the spring. When the hydraulic force is greater than the spring force, the piston begins to move upward, the spring compresses, and the valve begins to open.
As the hydraulic pressure increases, the valve continues to open. Conversely, as hydraulic oil is drained from the cylinder, the hydraulic force becomes less than the spring force, the piston moves downward, and the valve closes. By regulating amount of oil supplied or drained from the actuator, the valve can be positioned between fully open and fully closed.
The principles of operation of a hydraulic actuator are like those of the pneumatic actuator. Each uses some motive force to overcome spring force to move the valve. Also, hydraulic actuators can be designed to fail-open or fail-closed to provide a fail-safe feature.
  1. Hydraulic actuators are rugged and suited for high force applications. They can produce forces 25 times greater than pneumatic cylinders of equal size. They also operate in pressures of up to 4,000 psi.
  2. A hydraulic actuator can hold force and torque constant without the pump supplying more fluid or pressure due to the incompressibility of fluids.
  3. Hydraulic actuators can have their pumps and motors located a considerable distance away with minimal loss of power.
Hydraulics will leak fluid. Like pneumatic actuators, loss of fluid leads to less efficiency and cleanliness problems resulting in potential damage to surrounding components and areas.
Hydraulic actuators require many complementary parts, including a fluid reservoir, motor, pump, release valves, and heat exchangers, along with noise reduction equipment.
Articles You May Like :
Hydraulic System
Speed of Actuators
Double-ported Globe Valve
How to Select an Actuator
JT Valve Working Principle
Solenoid Valves Types & Functions
Common Valve Abbreviations in US Engineering Drawings
How Pilot operated Solenoid Valve Works ?
What is a Fail-Close Valve? – Advantages and Disadvantages
Compare Solenoid Valve Manual Reset and Solenoid Manual Override
What is Motor Actuator ?
2 Comments
  • vdo dono says:
    September 12, 2017 at 5:48 am
    I have been following this site for one year,this is very informative site with lots of precious information.pretty good work admin,hats off….
  • Apeh Innocent says:
    July 14, 2018 at 1:53 pm
    Am glad for the information. Thank.
Solenoid Valves Terminology
Erratic Stroking Control Valves Delaying the Shutdown Plant Restart
Solenoid Valve’s Energized or De-energized State ?
Objective Questions on Valves
Quick Exhaust and Air Operated Valves in Instrumentation Circuit
Pressure Relief Valve Terminology
What is Cage-guided Globe Valve ?
How to Do Maintenance of Control Valve Which is Stuck in Field?
Classification of valves
Introduction to Types of Valves
Direct Acting Actuators
Effect of Differential Pressure on Control Valve Lift
What is Swing Check Valve ?
3-way-2-position-solenoid-valve-spring-return
Pneumatic Directional Control Valves
How Valve Positioners act as Cascade Control Systems in a Loop?
Air Pressure Regulator cut-away diagram
Air Pressure Regulator Questions
Internal Parts of Globe Valve
How to Choose a Control Valve?
valve trim characteristics
Control Valve Trim Characteristics
cut way synchronous motor
Synchronous Motors MCQ – Multiple Choice Questions
What is a Process Alarm
What is a Process Alarm? Types of Alarms
How do Electric Motors Work
All About Electric Motors and Universal Motors
Corona-Ring-on-Surge-Arresters
Quadrupole Mass Spectrometer
Traffic Lights Ladder Diagram using Timers
How to Select the Right Encoder for Your Machine
How to Select the Right Encoder for Your Machine?
What is ELCB
What is ELCB? Principle, Advantages, Disadvantages, Applications
