Reading: PLC Data Comparison Instructions
Inst Tools > Blog > PLC Tutorials > PLC Data Comparison Instructions
Last updated: March 4, 2021 4:43 pm
As we have seen with counter and timers, some PLC instructions generate digital values other than simple Boolean (on/off) signals.
Counters have current value (CV) registers and timers have elapsed time (ET) registers, both of which are typically integer number values.
Many other PLC instructions are designed to receive and manipulate non-Boolean values such as these to perform useful control functions.
The IEC 61131-3 standard specifies a variety of data comparison instructions for comparing two non-Boolean values, and generating Boolean outputs.
The basic comparative operations of “less than” (<), “greater than” (>), “less than or equal to” (≤), “greater than or equal to” (≥), “equal to” (=), and “not equal to” (6=) may be found as a series of “box” instructions in the IEC standard:
PLC Data comparison instructions
The Q output for each instruction “box” activates whenever the evaluated comparison function is “true” and the enable input (EN) is active.
If the enable input remains active but the comparison function is false, the Q output de-activates. If the enable input de-de-activates, the Q output retains its last state.
A practical application for a comparative function is something called alternating motor control, where the run-times of two redundant electric motors are monitored, with the PLC determining which motor to turn on next based on which motor has run the least:
PLC Push Button Wiring
PLC on-delay timers logic
.In this program, two retentive on-delay timers keep track of each electric motor’s total run time, storing the run time values in two registers in the PLC’s memory:
Motor A runtime and Motor B runtime. These two integer values are input to the “greater than” instruction box for comparison.
If motor A has run longer than motor B, motor B will be the one enabled to start up next time the “start” switch is pressed.
If motor A has run less time or the same amount of time as motor B (the scenario shown by the blue-highlighted status indications), motor A will be the one enabled to start.
The two series-connected virtual contacts OUT motor A and OUT motor B ensure the comparison between motor run times is not made until both motors are stopped.
If the comparison were continually made, a situation might arise where both motors would start if someone happened to press the Start pushbutton with one motor is already running.
PLC Tutorials :
  • What is Programmable Logic Controller  ?
  • What is Ladder Diagram Programming ?
  • History of Programmable Logic Controllers
  • Mis-conceptions of PLC Ladder Logic
  • Contacts and coils in PLC
  • Digital Input and Output Modules
  • Analog I/O and Network I/O
  • PLC Input/Output Modules
  • Memory Mapping in PLC
  • Analog Input Scaling
  • PLC Example with Switches
  • Counter Instructions
  • Timer Instructions
  • Math instructions
  • Data Instructions
  • Ladder Logic Questions
How to Use the Shift and Rotate Instructions in PLC?
Process Interlocks and Trips
Mail Box Automation: Programming with Schneider PLC
How to Create Templates in FactoryTalk View Studio?
SCADA Hardware and Software
Features of Scada Which are Must in an IoT System
Difference between Power Cables and Signal Cables
Remote Factory Acceptance Test
Function Blocks in PLC (FBs) – What You Need To Know?
PLC Program for Controlling Sequence of Conveyors with Interlock
Peripheral Inputs and Outputs in Siemens PLC
What is Interposing Relay in a PLC System ?
SCADA Engineer Job Responsibilities and Skills
How to use Scale and Normalize Instructions in PLC
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
Distributed IO for Siemens PLC
How to Configure Distributed IO in a PLC Project?
How a PLC communicates with Transmitters
How PLC Reads the Data from Field Transmitters
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Allen Bradley PLC Example with Sub routines
How to use Sub Routines with Allen Bradley PLC
Siemens PLC motor direction control example
Siemens TIA Portal: Motor Forward Reverse PLC Logic
DC Circuit
Main differences between Sinking and Sourcing Circuits
Safety Instrumented Systems Online Exam
PID Block in RSLogix 500
Transformer Efficiency and Loses Formula
orifice plate vent hole
What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Types of Sensors Used in Automobiles
V1000 Family Programming Simulator Tool
Thermal Differential Level Measurement
What is Thermal Differential Level Measurement?
Generated EMF Quiz
