Reading: Create Logic with InTouch Scada using Scripting
Inst Tools > Blog > PLC Tutorials > Create Logic with InTouch Scada using Scripting
Last updated: March 4, 2021 12:21 pm
3 Min Read
Learn how to create logic using Wonderware InTouch SCADA software using the scripting language.
InTouch Scada Scripting
There are six types of logic gates. We can create a voting system using them and also, we can create PLC programming logic using a combination of them.
Here I will create a script to turn ON lamp by using all logic gates. To do that so, open InTouch application.
Step 1:
Create a new project and enter an animation environment as shown in the below window.
InTouch Project
Step 2:
Go to the wizard as shown in the below window. And add a switch and lights. As we are using six logic gates we will add twelve switches and six lamps.
Wizard Selection in InTouch Scada
Step 3:
Add all the objects as shown in the below window. Give tag name as per text. Do read my article on it.
Assign Tag names in InTouch scada
Step 4:
Right-click on the display as shown in the below window. Select “windows script”.
Windows Script in InTouch Scada
Step 5:
The following scripting window will open. Select condition type. In “on a show” it will always remain starting condition.
In “while showing” option, we have to write a script to operate switch and lamp. Also, select every and enter some time in it.
InTouch HMI Scripting
Step 6:
Here, I have added an initial condition as shown below. It always remains zero.
SCADA Scripts
Step 7:
In “while showing” I have written condition to turn OFF and ON gate, based on the type of logic gate and lamp will turn ON accordingly.
intouch show window script
Step 8:
After writing down condition click on “validate” than “convert” and then hit “ok”.
To test the logic click on “runtime” located on the top right of the below.
InTouch SCADA Condition script Tutorial for Beginners
Step 9:
When switches are OFF NAND, NOR AND XNOR gates will remain ON.
Switch Simulation in InTouch Scada
Step 10:
When S1 is ON then OR, NAND, and XOR gate’s lamp will turn ON.
Logic Gates in InTouch Scada
Step 11:
When S2 is ON then OR, NAND, and XOR gate’s lamp will turn ON.
InTouch SCADA scripting language
Step 12:
When both S1 and S2 are ON then the lamp of AND, OR and XNOR will turn ON.
Creating Logic in Intouch Using Scripting
Author: Suhel Patel
  • Quiz Questions on Motors
  • Modifying PLC Programs
  • Field instrument to Control Room
  • What is SCADA System?
  • Siemens Profinet Configuration
PLC Program for Traffic Light Sequence using Functional Blocks
PLC Analog Input Card Resolution Effects on Accuracy
PLC Commissioning and Testing Procedure (Programmable Logic Controller)
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Tank Filling and Emptying using Intouch Scada Script
Step by Step Guidelines for Downloading Free PLC software
Relay Operation, Types, Symbols & Characteristics
SCADA for Substation Automation
PLC Ladder Logic Example based on Set Coil and Reset Coil
Motor ON OFF Logic in PLC
PLC Pneumatic Circuit Control
Allen Bradley Studio 5000: Motor Running Hours PLC Program
Machine Indicator Lights PLC Programming Solution
PLC Programming in Bottle Filling Process
Applications of PLC Programming in Bottle Filling Process
Allen Bradley PLC communication is established
Procedure for Connecting Allen Bradley PLC and PC – RS Logix 500
PLC Ladder Program for Automatic Car Wash
PLC Ladder Program for Automatic Car Wash using Siemens TIA Portal
PLC to PLC Communication using S7 Connection
PLC to PLC Communication using S7 Connection PUT & GET Instructions
PID parameters
PID in Siemens TIA Portal
DCS
DCS
MCQ on PLC (Programmable Logic Controller)
What is a Process Alarm
What is a Process Alarm? Types of Alarms
Digital Electronics Objective Questions – Set 4
Sensors & Transducers Questions and Answers
Modbus Network Motor Control
Motor Control using Modbus Communication and Hardwired Signals
Comparison of CB, CE & CC Amplifiers
Comparison of Transistor Configurations
Hydrostatic Level Measurement
Power System Interview Question and Answers
What is a Flange Gasket ?
