Reading: What is Sequential Function Chart (SFC?)
Inst Tools > Blog > PLC Tutorials > What is Sequential Function Chart (SFC?)
In this article, we will discuss the sequential function chart. SFC is a flow chart-like programming language in PLC.
Last updated: September 28, 2022 2:33 pm
R Jagan Mohan Rao
As per IEC 61131-3, there are five PLC programming languages, three are graphical. The other two are textual languages.
Sequential Function ChartProgram operationMerits of Sequential Function Charts (SFC)
The three graphical languages are ladder diagram (LD), Function Block Diagram (FBD), Sequential Function Chart (SFC). Two textual languages are Standard Text (ST) and Instruction List (IL).
Out of all the above, various languages have different strengths for different tasks.
In this article let us discuss Sequential Function Chart (SFC). It is a flow chart-like programming language. The execution of process operations is structured sequentially. It can encapsulate ladder diagram (LD), Function Block Diagram (FBD), Instruction List (IL), and Standard Text (ST) structures to control subroutines.
Sequential Function Chart (SFC) can be used to structure the internal organization of a program consisting of sub-programs and are also written in other languages of the standard. It can also be used in its pure form of specifying the logical control algorithms.
The SFC programming structure consists of three main elements that organize the control program.
A program in SFC consists of
  • Steps (Stages)
  • Transitions
  • Actions.
Stages
Each stage indicates the state of the process. A step can be active or inactive.
As shown in the figure below, a transition not only can have one input step and one output step but also can have more input steps and more output steps, connected by the directed links.
These sequential flow chart diagrams show the stages in sequential order and are widely used to present algorithms, workflow, or process flow.
Typically, a sequential flow chart displays the steps as charts of various kinds. Their order is established by connecting them with lines.
The stages involve associated actions.
Only some of the stages can be found active in each cycle of the process.
Each stage is identified with a number that must be unique and not it must necessarily keep an order consistent with the sequence of the process.
Transitions
Transition in Sequential Function Chart
In between two steps, a transition is a step represented by a horizontal line across a vertical line. It is containing the logic condition allowing the transfer from one step to another.
Transitions are associated with a condition, these can be a logical function of variables of input and internal system.
Actions
Sequential Function Chart Action
The actions associated with the stages are represented by a rectangle sidebox where the type of action to be carried out is indicated (only the active ones). A stage can have one or more actions associated with it.
The process is broken down into stages, which will be activated sequentially.
One or more actions are associated with each stage. These actions will only be active when the stage is active.
The activation of a transition condition indicates the activation of the next stage and the deactivation of the preceding stage.
Program operation
Sequential Flow Chart (SFC) steps are connected with each other same as the flow chart. SFC is conducive to Boolean operation AND or OR decisions. AND decisions are simply placed in series and OR decisions are placed in parallel.
There are two ways to indicate conditions
  • Symbolic and
  • Literal
Between stage and stage, there must be a transition. The Transition conditions are written to the right of the line that joins them. There may be a jump or step backward seen same as flow charts.
A condition is associated with every transition. If all the input steps of a transition are active, and the transition condition is satisfied then the transition is fired, which means deactivation of all its inputs steps and activation of all its output steps.
A Typical Sequential Function Chart
It is a graphical language that provides a diagrammatical representation of control sequences in a program.
  • Similar to a flow chart.
  • Useful for sequential control operations.
  • Shows the main states of a system.
  • SFC shows all possible status changes.
Sequence Function Chart (SFC) is suggested by many programming and modeling platforms for logic controllers such as step 7 by SIEMENS and control builder by ABB.
  • Process Control
  • Power Factor Controller
  • Building Management System
  • PLC Hardware Troubleshooting
  • Instrumentation Symbols Legend
Modbus Communication between PLC and Energy Meter
PLC Program with 2 Toggle Switches and 4 Motors
PID Controllers in Closed Loop Control Systems – PLC Basics
Memory Structure of Siemens PLC
Configuration of Siemens VFD Using TIA Portal Start drive
Laws of Boolean Algebra using Ladder Logic
Evaluating Industrial Automation Projects Return on investment (ROI)
Difference Between PLC and CNC Machine
Surface Grinding Process using PLC Program
PLC Timer Practice Exercise: Coffee Machine Programming
PLC Program for Traffic Light Sequence using Functional Blocks
Flip-Flop PLC Programming: Lights with Adjustable Timers
PLC Logic for Automatic Bending Machine for Exhaust Pipe
OB and FB Blocks in Siemens PLC
Procedure for Siemens S7-300 Download from PC to PLC
PLC Programming for Garden Sprinkle System
PLC Programming for Garden Sprinkler System
Types of PLC
Types of PLC
Logic for Always ON and Always OFF bit
Always ON and OFF Bit using Ladder Logic and Statement List
What is Hot Standby in PLC
What is Hot Standby in PLC?
Yokogawa DCS CPU
System Cabinet Health Checks – PLC and DCS Industrial Automation
PLC Program to Drain Same Products from Two Tanks
Two Hand Press PLC
Two Hand Press Safety Control Circuit
Pneumatic Transmitter
Questions on Pneumatic Transmitter and Repeater
How to Troubleshoot a PLC System
How to Troubleshoot a PLC System?
Microprocessors Objective Questions – Set 7
Pressure Regulators vs Pressure Control Valves
Pressure Control Valves vs Pressure Regulators
Manual Call Point Testing Procedure
Questions on Resistive Tape Level Sensor
Transformer Efficiency
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
