Reading: What is a Control Panel and its types?
Inst Tools > Blog > Control Systems > What is a Control Panel and its types?
Last updated: October 17, 2023 2:19 pm
R Jagan Mohan Rao
Control Systems PLC Tutorials
Control panel is used to accommodate instruments for the purpose of measurement, monitoring, protection, detection, control and manage the processes.
Control PanelTypes of Control PanelsFlat Control PanelBreakfront PanelConsole
The panels are located in a control room as well as a field termed as a local control panel (LCP) for operational convenience.
Control Panel
Control Panel
The control panels are designed based on the type of energy and dynamics associated. Panels are named based on a functional media such as electrical, electronic, air, and oil.
  • The panel is called PLC control panel with a PLC installed, associated wiring, power supplies.
  • If the panel is Pneumatic controller/ Indicators which are operated by air is called pneumatic control panel with associated controllers, transducers gauges, etc.,
  • If a panel is called hydraulic, if it is operated by oil with associated pressure gauges, directional control valves, etc.,
The modern industry uses instruments for the management of various parameters such as electrical (voltage, current, power) process temperature, pressure, flow, acceleration, density, level mass, volume compositions.
The electronic instrument panels are needed to be placed away from high switch noise-producing elements such as VFD, motors, and pumps. Signal noise effects the measurement.
There are three basic types of control panels.
  1. Flat Control Panels
  2. Breakfront Control Panels
  3. Console type Control Panels
The dimensions of a particular panel type are as per the suitability of the application.
Flat Control Panel
The flat control panel is the least expensive and easiest to construct and simple design of all types.
Flat Control Panel
The straight and vertical plane of the panel allows an orderly layout of tubing, electrical ductwork, and miscellaneous equipment.
Instruments can be arranged as per the operator’s convenience and requirement. Flat control panels are best suitable for PLC/DCS system installation.
Breakfront Panel
Breakfront panels allow greater use of the front plane of the board.
The top portion of the panel is swung downwards to an angle normal to the line of sight allowing better visibility.
Console
The Console appears to be eye-catching and very pleasing to most people.
Operator Console Panel
Normally their length is set by the operator’s unit responsibility limits. i.e operator for one console and one console for one operator.
The length varies from 4 to 12 feet.
Consoles are often coupled with ‘’flat backup” panels which contain large-sized instruments and auxiliary components.
Auxilliary equipment such as pressure switches, transducers. As the console is built with limited area, troubleshooting of instruments becomes a real problem with limited area to work for the maintenance team.
Console Panels
  • Industrial Automation Systems
  • What is a Fire Alarm System?
  • Project Planning DCS System
  • Functions and Parts of PLC
  • What is Mimic Panel?
PLC Program for Positive Edge Pulse Output for One Scan Cycle
Relation Control System
Industrial Automation in the Mining Industry
Configuration of Profibus Network in Siemens PLC
PLC Programming for Traffic Barrier Control
100+ Questions and Answers on Industrial Automation and Control
Difference Between Batch Process and Continuous Process
100 PLC Quiz Questions : True or False
Two Hand Press Safety Control Circuit
How a PLC communicates with Transmitters
How PLC Reads the Data from Field Transmitters
Advanced Process Control
What is Advanced Process Control (APC)?
Different Control Modes of Air Handling Unit (AHU)
Control Modes of Air Handling Unit (AHU) – HVAC Basics
InTouch SCADA Password Protection
InTouch SCADA Login Password Security
3 to 8 Line Decoder Circuit Diagram
3 to 8 Line Decoder PLC Ladder Diagram
Why Are Charcoal and Salt Added to an Earthing Pit
Why Are Charcoal and Salt Added to an Earthing Pit?
PLC Programmer Tools
Types of Angular Velocity Measurement
Parity Checkers Objective Questions
How to Update the Firmware Version of your PLC
How to Update the Firmware Version of your PLC? – TIA Portal
Fiber Optic Sources and Detectors Questions
Fiber Optic Sources and Detectors Questions and Answers
Memory Devices Objective Questions – Part 4
Remote Seal Pressure Transmitter Temperature
Importance of Temperature in Remote Seal Pressure Transmitter
DDE Protocol
What is the DDE Protocol?
instrumentation engineering standards
ISA codes for Process Instrumentation
