Reading: Valve Seat Leakage Test
Inst Tools > Blog > Control Valves > Valve Seat Leakage Test
Last updated: July 20, 2019 3:09 pm
Control Valves
2 Comments
3 Min Read
In some process applications, it is important that the control valve be able to completely stop fluid flow when placed in the “closed” position. Although this may seem to be a fundamental requirement of any valve, it is not necessarily so.
Many control valves spend most of their operating lives in a partially-open state, rarely opening or closing fully. Additionally, some control valve designs are notorious for the inability to completely shut off (e.g. double-ported globe valves).
Given the common installation of manual “block” valves upstream and downstream of a control valve, there is usually a way to secure zero flow through a pipe even if a control valve is incapable of tight shut-off. For some applications, however, tight control valve shut-off is mandatory.
For this reason we have several classifications for control valves, rating them in their ability to fully shut off.
Seat leakage tolerances are given roman numeral designations, as shown in this table:
Valve Seat leakage tolerances
The “bubble test” used for Class VI seat leakage is based on the leakage rate of air or nitrogen gas past the closed valve seat as measured by counting the rate of gas bubbles escaping a bubble tube submerged under water.
For a 6 inch valve, this maximum bubble rate is 27 bubbles per minute (or about 1 bubble every two seconds):
Valve Seat leakage Test
It is from this leakage test procedure that the term bubble-tight shut-off originates. Class VI shut-off is often achievable only through the use of “soft” seat materials such as Teflon rather than hard metal-to-metal contact between the valve plug and seat.
Of course, this method of achieving bubble-tight shut-off comes at the price of limited operating temperature range and the inability to withstand nuclear radiation exposure.
Special test fixtures are typically used in control valve rebuild shops to test the leakage rates of a rebuilt valve. One such test bench appears in this photograph:
control valve workshop
In the foreground of this photograph we see a special “vise” used to make quick, pressure-tight connections to the flange of any control valve placed within it.
A movable flange sandwiches the control valve against a stationary flange, both flanges faced with high-density plastic for a pressure tight fit against the valve body flange faces.
A stainless-steel panel in the background provides a set of air pressure regulators, hand valves, rotameters, pressure gauges, and even a “bubble” flow indicator to measure leakage flow rate through the control valve under varying pressure conditions.
Articles You May Like :
Flow Meter Calibration
What is Swing Check Valve ?
What is ON/OFF valve ?
What is Gate Valve ?
Dome Valve Principle
Digital Control Valves – Introduction, Principle, Setup, Applications
Solenoid Valve with Manual Reset Working Principle
Introduction to Types of Valves
Face to Face Dimension of Control Valve
Difference Between the Control Valve and Shut-off Valve
2 Comments
  • Asif Attari says:
    March 1, 2018 at 7:33 am
    For control valve seat leakage, now as per new standard ANSI-FCI-70-2013, Class V valves can be tested through air also. If possible, please can you share this standard also on this website. Thanks,
  • Kibar says:
    April 23, 2023 at 8:07 pm
    Sir, can you give one example seat leakage calculation for class IV control valve CV 575
What is Shutdown Valve?
Working of Rupture Disk
Difference between RTJ and T&G Flange Facings
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Fluid Power Systems
Pneumatic Directional Control Valves
What is a Hydraulic Valve? and their Types
Control Valve Performance with Constant Pressure
Piston Check Valve
What is Piston Check Valve ?
Steam conditioning valves
Concept of Steam Conditioning Valves
Tilting Disk Check Valve Principle
What is Tilting Disk Check Valve ?
Tie rods double acting cylinder
What is a Pneumatic Cylinder?
Stop Check valve
What is Stop Check valve ?
Self Actuated Pressure Control Valve Principle
Control Valves Chemical attack Problems
Internal Parts of Globe Valve
How to Choose a Control Valve?
History of Measurement
Transmission Lines Protection Questions Answers
Solenoid-Valve-Manual-Reset-function
Types of Interrupts Organization Blocks in Tia Portal
Types of Interrupt OB in Siemens Tia Portal
Logic for Always ON and Always OFF bit
Always ON and OFF Bit using Ladder Logic and Statement List
What is a Spare Part
What is a Spare Part? Classification, Cost, Critical Inventory
Start the Counting from a Preset Value in PLC
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
