Reading: Turbine Flow Meter – Principle, Advantages, Disadvantages
Inst Tools > Blog > Flow Measurement > Turbine Flow Meter – Principle, Advantages, Disadvantages
The turbine flow meter sends the liquid through a rotor causing it to rotate at an angular velocity proportional to the fluid flow rate.
Last updated: October 31, 2023 12:57 pm
Flow Measurement
4 Comments
6 Min Read
Turbine Flow Meter is a volumetric measuring turbine type. The flowing fluid engages the rotor causing it to rotate at an angular velocity proportional to the fluid flow rate.
Turbine Flow MeterApplications of Turbine Flow MetersCautions for Turbine Flow metersAdvantages of Turbine Flow MetersDisadvantages of Turbine Flow Meters
The angular velocity of the rotor results in the generation of an electrical signal (AC sine wave type) in the pickup. The summation of the pulsing electrical signal is related directly to total flow.
The frequency of the signal relates directly to the flow rate. The vaned rotor is the only moving part of the flow meter.
Turbine Flow Meter
Turbine Flow Meter Principle
The Turbine flow meter (axial turbine) was invented by Reinhard Woltman and is an accurate and reliable flow meter for liquids and gases. It consists of a flow tube with end connections and a magnetic multi-bladed free-spinning rotor (impeller) mounted inside; in line with the flow. The rotor is supported by a shaft that rests on internally mounted supports.
 The Supports in Process Automatics Turbine Flow Meters are designed to also act as flow straighteners, stabilizing the flow and minimizing the negative effects of turbulence.
The Supports also house the unique open bearings; allowing for the measured media to lubricate the bushes – prolonging the flow meter life span. The Supports are fastened by locking rings (circlips) on each end.
Turbine Flow Meter Operation
The rotor sits on a shaft, which in turn is suspended in the flow by the two supports. As the media flows, a force is applied on the rotor wings. The angle and shape of the wings transform the horizontal force into a perpendicular force, creating rotation. Therefore, the rotation of the rotor is proportional to the applied force of the flow.
Turbine Flow Meter Animation
Because of this, the rotor will immediately rotate as soon as the media induces a forward force. As the rotor cannot turn through the media on its own, it will stop as soon as the media stops. This ensures an extremely fast response time, making the Turbine Flow Meter ideal for batching applications.
A pick-up sensor is mounted above the rotor. When the magnetic blades pass by the pickup sensor, a signal is generated for each passing blade. This provides a pulsed signal proportional to the speed of the rotor and represents pulses per volumetric unit.; and as such the flow rate.
Also Read: Flow Meters Troubleshooting Tips
In order of magnitude from largest to smallest,
  • these are used in oil and gas,
  • water and wastewater,
  • gas utility,
  • chemical,
  • power, food, and beverage,
  • aerospace, pharmaceutical,
  • metals and mining, and pulp and paper.
Turbine meters are less accurate at low flow rates due to rotor/bearing drag that slows the rotor. Make sure to operate these flow meters above approximately 5 percent of maximum flow. Turbine flow meters should not be operated at high velocity because premature bearing wear and/or damage can occur.
Be careful when measuring fluids that are non-lubricating because bearing wear can cause the flow meter to become inaccurate and fail. In some applications, bearing replacement may need to be performed routinely and increase maintenance costs.
Application in dirty fluids should generally be avoided so as to reduce the possibility of flow meter wear and bearing damage. In summary, turbine flow meters have moving parts that are subject to degradation with time and use.
Abrupt transitions from gas flow to liquid flow should be avoided because they can mechanically stress the flow meter, degrade accuracy, and/or damage the flow meter. These conditions generally occur when filling the pipe and under slug flow conditions. Two-phase flow conditions can also cause turbine flow meters to be measured inaccurately.
  • Wide flow rangeability including low flow rates
  • The turndown ratio is up to 35:1
  • Good level of accuracy at an economic price
  • Simple, durable construction
  • Easy to install and maintain
  • Flexible connection to flow instruments for flow control
  • Wide variety of process connections
  • Turbine meters can operate over a wide range of temperatures and pressures
  • Low-pressure drop across the turbine
  • Provides a convenient signal output
  • Requires constant backpressure to prevent cavitation
  • Accuracy is adversely affected by bubbles in liquids
  • Turbine meters can be used with clean liquids and gases only (may need to install a strainer upstream to prevent damage from particulates)
  • Not applicable for measuring corrosive fluids
  • Requires a turbulent flow profile (consistent fluid velocity across the pipe diameter) for accuracy
  • Sensitive to changes in fluid viscosity
  • Require a straight run of pipe before and after the turbine meter to allow swirl patterns in the flow stream to dissipate
  • May not function properly with high-viscosity fluids where the flow profile is laminar
  • Flow Meter Calibration
  • Types of Flow Meters
  • Animation of Vortex meter
  • Animation of Flow Switch
  • Turbine Flow meter K Factor
What is a Coriolis Flow Meter?
What is Gas Meter and Regulating Station?
Hot Wire Anemometer Principle and Types
Configure the Instruments in Flow Control Loop
DP type Flow Transmitter Preventive Maintenance and Calibration
4 Comments
  • Lilya says:
    May 10, 2018 at 12:45 am
    The site is great!!!! It is extremly useful!
  • Yogesh says:
    March 5, 2021 at 4:21 pm
    Why increase in Viscosity is Reducing rangeability of Turbine FM?
  • Gary Riley says:
    November 30, 2022 at 8:56 am
    Hi help please I’m trying to repair an OTC turbine flow metre-tester having trouble working out k factor information I have from inside the metre is 2,000 RPM =100hz. 100hz = – – – – G.P.M. ? Or litres min. & 650hz.= – – – – G.P.M. Or litres min. Can you help me so I don’t pull all my hair out? Regards Gary
  • Teltherm Instruments Ltd says:
    July 5, 2023 at 5:10 pm
    The working principle of a turbine flow meter is expertly explained in this article by Instrumentation Tools. The detailed description of how the flow of fluid causes the turbine to rotate and the subsequent measurement of flow rate is informative and easy to understand. The article also covers the advantages and limitations of turbine flow meters, offering a well-rounded perspective. Instrumentation Tools consistently provides valuable information on instrumentation and measurement techniques. Thank you for sharing this insightful article!
Difference between Fixed Area & Variable Area FlowMeters
Why Turndown Ratio is important when Selecting a Flow Meter?
What is a Square Root Extractor? – DP Flow Measurement
Venturi Flow Meter – Working Principle, Advantages, Animation
What is an Orifice Flange? – Purpose and Applications
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Weirs and Flumes Flow Measurement
Facts About Orifice Flow Meters
Coriolis mass flowmeter Density Measurement
How Coriolis Mass Flow Meter Measure Density?
Thermal Mass Flowmeter Principle
Thermal Mass Flow Meter – Principle, Advantages, Applications
Turbine Flowmeter Parts
What is a Turbine Flow Meter?
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Thermal Dispersion Flow Switch Working Principle
Swirl Flowmeters Principle
Swirl Flow Meters Working Principle
Vortex Flow Meter Animation
API 2000 Sizing Calculator - Tank Blanketing Valves
API 2000 Sizing Calculator – Tank Blanketing Valves
SMART Control Valve Positioner
Electronic Valve positioners
Electric Short Circuit
Series Short Circuit Faults
Process Switches Normal Status
Effects of Long Distance Cables on VFD
Effects of Long Distance Cables between VFD and Motor
Instrumentation Dictionary
Armature Winding Questions
cross
Tube Fitting Types
