Reading: Transmitter Detailed Specifications
Inst Tools > Blog > Instrumentation Design > Transmitter Detailed Specifications
Last updated: March 28, 2022 11:19 am
2 Comments
Here we shall see detailed specifications of Transmitters used for Level, Pressure, Flow, DP applications.
Transmitter SpecificationsExample Specifications
Transmitter used for flow, pressure, level, and DP applications are generally 2 wire 4-20 mA type depending on application and existing plan control system compatibility.
Sometimes foundation Fieldbus and Profibus protocols are also used for various applications.
Generally, transmitters should have the following features.
  • Transmitters should be SMART type
  • 2 wire 4-20 milliampere signal to be used
  • Should support HART protocol
Generally, transmitters shall be
  • Certified Ex-proof and for intrinsic safe applications Ex ia/ib rated
  • Die-cast Aluminium housing
  • Compatible with Direct mount or remote mounting accessories
Wetted part material normally is SS 316, as a minimum depending on process suitability. 125-150% of over-range protection is generally required.
Both coplanar and in-line transmitters are to be used for different applications.
External zero adjustment and internal vent/drain provision required.
Transmitter capable of measuring gauge / absolute pressure
The transmitter should be field configurable and should support multiple units of measurement.
Microprocessor-based control chip inside transmitter required with non-volatile memory to store configuration.
Signal conversion should be carried out in the transmitter itself and the design of the electronics should comply with Electromagnetic Compatibility requirements as per IEC 60801.
It should be capable of self-diagnosis and in event of failure, it should retain the fail safe value of output.
Built-in temperature sensors shall be provided for temperature compensation wherever required.
Instrument connection on Transmitter should generally be ½” NPT.
Various types of certifications should be available to choose from depending on the region it is to be used for example the USA or Europe.
Transmitter accuracy should be +/- 0.1% minimum but it is not possible for every case for example orifice meters do not provide that much accuracy because of the complexity of the measurement mechanism but the transmitter selected should have min +/- 0.1% accuracy.
Normally transmitter is calibrated in a way that it should read process LRV at about 25% of its measurement span and it should read URV at about 80%.
The transmitter should have internal transient protection inbuilt.
The transmitter shall support the latest version of the HART protocol. It shall also support multiple alarm level signal transmission. Typically these signals are superimposed over a 4-20 mA signal.
Transmitters for anti-surge control loops are non-smart type and flameproof unless specified otherwise.
A special smooth surface finish is required for sanitary services.
Generally, process connection for pressure and differential pressure transmitter shall be ½” NPTF and flanged for diaphragm seal type. Diaphragm seal element is used for corrosive and highly viscous services at high operating temperatures.
Capillary material SS 316 as a minimum, shall have SS 304 armoring with PVC cover, and for minimum measurement lag, proper ID should be selected.
Transmitter shall be installed with 2/3/5 valve manifold wherever it needs frequent removing of the transmitter for maintenance purposes.
Here a snapshot from the brochure of one of the vendors of Transmitters is given for reference.
Author: Kalpit Patel
  • Flowmeter Control Strategy
  • What is Averaging Pitot Tube?
  • Basics of Venturi Flow Meter
  • Differential Pressure Flowmeter
  • Flow Transmitter Square-Root
Turbine-Compressor System Architecture
Compliance Table Application (for Procurement Service Cycle)
Air Cylinder Consumption Calculation for Control Valves
Response Time Test of RTD and Thermocouple
2 Comments
  • Isaac Nyame says:
    June 28, 2020 at 10:07 pm
    Interesting, you people are doing very well
    • Mr. Shah says:
      June 10, 2024 at 12:51 pm
      Thank you
Process Control & Safety Systems Logics Implementing Cycle
Instrumentation and Process Teams Interactions in Design Engineering Companies
Pressure Control Valves vs Pressure Regulators
What’s the problem with shock and vibration ?
How to Select a Pneumatic Manifold
What is Instrument Heated Enclosure or Protection Box?
How-to Create Instrument Loop Diagram (ILD)?
15 Loop Diagram Questions
How to Solve Cable Tray Sagging
How to Solve Cable Tray Sagging ?
Cable screen shall not be grounded
Cable Screen shall not be Grounded at Field Device ?
Switch or Transmitter
Design & Construction of Process Plant
Flow Control Valves
Difference Between a Flow Control & a Needle Valve
ISA and SAMA diagrams
What is SAMA Diagram?
IS Loop Formula
Difference between Intrinsic Safe and Non-Intrinsic Safe Cables
Formulas to calculate ma from PV
Formulas to calculate mA from PV, LRV and URV
Thermal Mass Flowmeter Principle
Thermal Mass Flow Meter – Principle, Advantages, Applications
Two pressure transmitters
Pressure Transmitters Leg Compensation Technique
PLC Program for Star Delta Starter using Functional Block Diagram
How to do Control Valve Sizing
How do you do control valve sizing in Layman’s terms?
Gas Solid Chromatography Questions & Answers
Servo Operated Manometer Objective Questions
Deluge System for Transformer Protection
Deluge System for Transformer Protection Animation
