Reading: Thermal Imaging Temperature Measurement
Inst Tools > Blog > Temperature Measurement > Thermal Imaging Temperature Measurement
Last updated: March 13, 2019 6:19 pm
6 Min Read
A very useful application of non-contact sensor technology is thermal imaging, where a dense array of infrared radiation sensors provides a graphic display of objects in its view according to their temperatures.
Each object shown on the digital display of a thermal imager is artificially colored in the display on a chromatic scale that varies with temperature, hot objects typically registering as red tones and cold objects typically registering as blue tones.
Thermal imaging is very useful in the electric power distribution industry, where technicians may inspect power line insulators and other objects at elevated potential for “hot spots” without having to make physical contact with those objects.
Thermal imaging is also useful in performing “energy audits” of buildings and other heated structures, providing a means of revealing points of heat escape through walls, windows, and roofs.
In such applications, relative differences in temperature are often more important to detect than specific temperature values. “Hot spots” readily appear on a thermal imager display, and may give useful data on the test subject even in the absence of accurate temperature measurement at any one spot.
Again, it is important to stress that thermal imaging only provides an assessment of the object’s surface temperature, and not the temperature within that object.
Variations in surface temperature detectable by thermal imaging are a secondary effect of temperature variations within the object, and as such may not accurately depict the true thermal gradient(s) within the object.
A digital image taken with a thermal imaging instrument by maintenance personnel at a municipal water treatment facility shows “hot spots” on an electric motor.
A color scale on the right-hand side of the image serves as a “legend” for interpreting color as temperature. In this particular shot, dark blue is 68.1 oF and white is 152 oF:
This particular electric motor is in a vertical orientation, with the electrical connection box in the upper-left corner and two prominent hot spots on both the near and the left-facing sides of the case.
A manual valve handle appears in the foreground, silhouetted in dark blue against a lighter blue (warmer) background.
A lifting “eye” on the motor case appears as a green (cooler) shape in the middle of a white (warmer) area. The two “hot spots” correspond directly to stator windings and magnetic pole faces inside the motor, which are close enough to the motor’s casing to cause variations in surface temperature.
Thermal imaging is particularly useful for detecting hot spots on equipment unsafe to directly touch, as is the case with many “live” electrical components.
This next thermal image shows an operating three-phase motor starter (contactor and overload block):
Temperature Measurement using Thermal imaging
The bright spot in the center of the contactor is the higher temperature of the electromagnetic coil, providing magnetic force to actuate the contactor mechanism.
Perhaps the most telling detail of this thermal image, however, is the difference in temperature between the overload heater connections (the six screws located near the bottom of the starter assembly).
Note how the middle heater’s screws register slightly higher temperatures than the screws on either of the other two heater elements.
Large temperature differences may indicate poor electrical connections (i.e. greater resistance) at the hot spots, or imbalances in phase current. It is also possible that the elevated temperature of this particular overload heater is simply due to it having less open surface area for it to radiate heat, since the two overload heaters flanking it enjoy the advantage of having more air cooling. If three people pack themselves into a narrow bench seat, the middle person is going to be warmer than either of the outer two!
Another noteworthy detail in this image is the “Spot Difference” measurement provided by the thermal imager.
A cross-hair cursor on the display serves to locate a particular spot in the image, which in this case is contrasted against a reference spot chosen in an earlier step.
The instrument automatically subtracts the current and reference spot temperatures to give a ΔT indication, in this particular case 84.7 oF.
A thermal image of a three-phase circuit breaker shows a much more even distribution of temperature:
Thermal imaging Temperature Measurement
The hottest objects in this image are the three load screw terminals, appearing as white/red against a blue/green background.
Note the range of the temperature scale on the right of the image: this particular image only spans a temperature range of 61.3 oF to 68.6 oF.
This narrow temperature range tells us the differences in temperature shown by colors in this image are nothing to worry about.
Here, the instrument provides a single-point temperature measurement of 68.4 oF at the cursor (“Spot”) location rather than a differential temperature measurement between two points.
RTD Calibration Procedure
Thermocouple Temperature Measurement Errors
How to calculate Thermocouple Temperature by measuring the output millivoltage
Burnout Function in Temperature Transmitter
Thermowell Problems
  • Naresh Nirwan says:
    November 30, 2023 at 2:59 pm
    Dear Sir
    We have keen interest in Thermal imaging device for our Thermal Spray process.
    During Metal Thermal Spray , processed job temperature will increase and we wants to measure surface temperature of the job with thermal image.
    The process is always perform in an acoustic chamber so we required the thermal image outside of the acoustic chamber.
    Please suggest us your compatible equipment for the application.
Functions of Temperature Detectors
Pressure and Temperature Gauges
Response Time Test of RTD and Thermocouple
Installation Precautions of Thermocouple and RTD
Difference Between 2 wire RTD, 3 wire RTD, and 4 wire RTD’s
What is a Head Mount Temperature Transmitter? – Advantages
Filled-bulb Temperature Sensors
Thermowell Installation near Critical Equipment
RTD Construction
Introduction to RTDs
Bimetallic Thermometer
Temperature Scanner
Applications of Temperature Scanner
How to Select Right Thermocouple and Thermowell
How to Select Right Thermocouple & Thermowell ?
Temperature Gauges and Elements Specifications
Temperature Gauges and Elements : Detailed Specifications
Temperature Measurement Questions
Interview Questions on Temperature Measurement
Thermocouple Calculations
Free Download Thermocouple Calculator
RTD Testing Methods
RTD Testing Methods in Calibration Laboratory
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Industrial Light Fittings and Street Light Poles Corrosion Problems
What is an Electrical Drive
What is an Electrical Drive? Types, Advantages, Disadvantages
Packing Compressing Die Set
Carbamate Plunger Pump Packing Problems Eliminated
Data Types in PLC
Data Types in PLC – Bit, Byte, Integer, Real, String
Simatic Hardware Configuration
Configuration of Profibus Network in Siemens PLC
Loop-powered 4-20 mA transmitter
Loop-powered 4-20 mA Transmitter Circuit Voltage drop
