Reading: How to test SCR using Multimeter
Inst Tools > Blog > Power Electronics > How to test SCR using Multimeter
Last updated: May 18, 2017 9:33 am
Power Electronics
2 Min Read
This post will discuss about testing SCR – Silicon Controlled Rectifier with thte help of Ohmmeter.
The thyristor pin assignment  diagram of TO-220 package is given for ready reference.
Identify the terminals of the Ohmmeter:
  • Using a junction diode, we can find out which ohmmeter lead is positive and which is negative.
  • Connect the general purpose PN junction diode to across the positive and negative terminals of the Ohmmeter.
  • The ohmmeter will indicate continuity only when the positive lead is connected to the anode of the diode and the negative lead is connected to the cathode.
  • The SCR can be tested with an ohmmeter based on this concept.
Procedure to Test the SCR with the help of Ohmmeter:
  • To test the SCR, connect the positive output lead of the ohmmeter to the anode and the negative lead to the cathode.
  • The ohmmeter should indicate no continuity.
  • Touch the gate of the SCR to the anode.
  • The ohmmeter should indicate continuity through the SCR.
  • When the gate lead is removed from the anode, conduction may stop or continue depending on whether the ohmmeter is supplying enough current to keep the device above its holding current level.
  • If the ohmmeter indicates continuity through the SCR before the gate is touched to the anode, it indicates that the SCR is shorted.
  • If the ohmmeter will not indicate continuity through the SCR after the gate has been touched to the anode, it indicates that the SCR is open.
Basics of Thyristor
Power Electronic Devices Specification and Classification
Power Electronics – Phase Controlled Half Wave Rectifier RL Load
How Snubber Circuit works ?
SCR Switching Characteristics
Turning Off SCR – Commutation
Top 100 Power Electronics Projects for Engineering Students
Thyristors – Switching, Two Transistor Model, Advantage, Applications
Types of IGBT
Power Diode – Characteristics, Construction, Working, Advantages
R R-C Firing Circuits Disadvantages
Introduction to Thyristor – History, Types, Principle, Advantages
Half-controlled Rectifier With R Load
Phase Controlled Rectifier – Half Controlled Rectifier with R Load
SCR Class B Resonant-Pulse Commutation
Thyristor Commutation Techniques – Types, Working Principles
Full-Controlled Rectifier Working Principle
Single-Phase Mid-Point Converter – Bridge Rectifier with Center Tap
Crowbar fault protection circuit
Symbol of Transistor
Power Transistor – Structure, Biasing, Characteristics, Advantages
Snubber Circuits
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
SCR Full Bridge Converter
Power Electronics – Full-wave Rectifier With R and RL Load
Basic components of power electronics
What is Power Electronics? Evolution, Block Diagram, Advantages
Random Access Memory Objective Questions – Part 1
Annubar Flow Meter Principle
Annubar Flow Meter – Principle, Advantages, Disadvantages
Industrial safety Objective Questions and Answers
Top 10 Industrial safety Objective Questions
Cascade Control System
Cascade Control
Smart Transmitter Calibration Tutorial
Smart Transmitter Calibration Tutorial Part 1
Digital Electronics Objective Questions – Set 6
PLC Sequence Programming Ladder Logic
Hardware Description Language Objective Questions
