Reading: Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
Inst Tools > Blog > Level Measurement > Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
Last updated: April 13, 2019 9:53 pm
Level Measurement Pressure Measurement
2 Comments
3 Min Read
Symmetric capillary
1. Seal Effect:
If the ambient temperature increases the capillary volume V will tend to exert forces on the DP seal (both sides).
Symmetric capillary1. Seal Effect:2. Hydrostatic Pressure:Asymmetric Capillary1. Seal Effect:2. Hydrostatic Pressure:Limitation
If both capillary have the same features (volume, seal thickness, fill fluid and length) are the same, all the resulting forces on the DP seal will be equal to zero (black DP seal position figure below).
The hydrostatic pressure figure below is P= ρ × g × D (where ρ and g are constants).
For the increase in ambient temperature, the density ρ will decrease.
This means the hydrostatic pressure P will decrease also. This will create an upper force (against the gravity force).
The resulting (final) DP seal position is shown in red figure below.
Symmetric capillary for Level Measurement
Figure – Symmetric capillary
Hypothesis: The volume V1 << to V (V1 is negligible)
1. Seal Effect:
If the ambient temperature increases the capillary volume V will tend to exert forces on one side of the DP seal (blue DP seal position in below Figure).
The hydrostatic pressure in Figure is P= ρ × g × D (where ρ and g are constants).
This means that the hydrostatic pressure P will decrease also. This will create an upper force (against the gravity force). This will tend to compensate the seal effect force.
The resulting (final) DP seal position is shown in blue in Figure.
Asymmetric capillary for Level Measurement
Figure – Asymmetric capillary
This asymmetric resulting force is inferior to the symmetric resulting force.
Limitation
Tall vessels and towers have posed a significant measurement challenge. In particular, long vertical tap‐to-tap distances require extended lengths of capillary to facilitate the installation.
As the tap‐to‐tap distance grows, the resulting head pressures within the capillary become too great to ‘tune’ out. Time‐response can be sub‐optimal on tall vessels and towers as the distance the pressure signal propagates through is substantially greater.
Overall, as the length of capillary attached to the transmitter low side increases, an accurate measurement becomes increasingly more difficult to achieve.
Remote Seal Transmitters Ranging Calculation
What are Mechanical Level Indicators? – Classification & Principle
Micro-impulse Level Transmitter Principle
Types of Pressure – Instrument Questions and Answers
The 5 ways Ultrasonic Sensors Work
2 Comments
  • tissa says:
    August 1, 2018 at 4:06 am
    I need the details of Level switch at Mollass for the fermented wash.
  • Abhay says:
    August 11, 2018 at 1:29 am
    Sir, can we download your informative articles for future reference? If yes then how?
Impulse Line Purging and Close Coupling of Instruments
Displacer Level Transmitter Dry Calibration with Weights
Magnehelic Gauge Calibration
Weight-based Level Measurement Principle
How can we use a DP Flow Transmitter for Level Measurement
Interface Level Measurement using DP Transmitter
Ultrasonic Level Switch Working Principle
Boiler Level Switch
Float level switch Principle
Which instrument is at fault in this system
Which Instrument is at Fault in this System?
Instruments Tapping Points
How to Install Ultrasonic Level Transmitters 5
Float & Dial Level Gauge Principle
Servo Level Transmitter Principle
Bellow Principle
Bellows
Ziegler-Nichols Closed Loop Tuning Procedure
Valve-Kv-Sizing-Calculator
Valve Kv Sizing Calculator
HART Multidrop Network
HART Communication Tutorial Part 2
Power Systems MCQ Series 21
CNC Custom Machining
What is Custom Machining in CNC? Why Should You Choose It?
Top 100 Switchgear and Protection Interview Questions
Electro deionization in a Water Treatment Plant
What is EDI in a Water Treatment Plant? – Electro deionization
Advantages of Star and Delta Systems
