Reading: Stability of Nonlinear System
Inst Tools > Blog > Multiple Choice Questions > Stability of Nonlinear System
1. Stability of a system implies that :
a) Small changes in the system input does not result in large change in system output
b) Small changes in the system parameters does not result in large change in system output
c) Small changes in the initial conditions does not result in large change in system output
d) Small changes in the initial conditions result in large change in system output
Answer: a
Explanation: Stability of the system implies that small changes in the system input, initial conditions, and system parameters does not result in large change in system output.
2. A linear time invariant system is stable if :
a) System in excited by the bounded input, the output is also bounded
b) In the absence of input output tends zero
c) Both a and b
d) None of the mentioned
Answer: c
Explanation: A system is stable only if it is BIBO stable and asymptotic stable.
3. Asymptotic stability is concerned with :
a) A system under influence of input
b) A system not under influence of input
c) A system under influence of output
d) A system not under influence of output
Answer: b
Explanation: Asymptotic stability concerns a free system relative to its transient behavior.
4. Bounded input and Bounded output stability notion concerns with :
Answer: a
Explanation: BIBO stability concerns with the system that has input present.
5. If a system is given unbounded input then the system is:
a) Stable
b) Unstable
c) Not defined
d) Linear
Answer: c
Explanation: If the system is given with the unbounded input then nothing can be clarified for the stability of the system.
6. Linear mathematical model applies to :
a) Linear systems
b) Stable systems
c) Unstable systems
d) All of the mentioned
Answer: b
Explanation: As the output exceeds certain magnitude then the linear mathematical model no longer applies.
7. For non-linear systems stability cannot be determined due to:
a) Possible existence of multiple equilibrium states
b) No correspondence between bounded input and bounded output stability and asymptotic stability
c) Output may be bounded for the particular bounded input but may not be bounded for the bounded inputs
Answer: d
Explanation: For non-linear systems stability cannot be determined as asymptotic stability and BIBO stability concepts cannot be applied, existence of multiple states and unbounded output for many bounded inputs.
8. If the impulse response in absolutely integrable then the system is :
a) Absolutely stable
b) Unstable
c) Linear
Answer: a
Explanation: The impulse response must be absolutely integrable for the system to absolutely stable.
9. The roots of the transfer function do not have any effect on the stability of the system.
a) True
b) False
Answer: b
Explanation: The roots of transfer function also determine the stability of system as they may be real, complex and may have multiplicity of various order.
10. Roots with higher multiplicity on the imaginary axis makes the system :
b) Unstable
c) Linear
Answer: b
Explanation: Repetitive roots on the imaginary axis makes the system unstable.
Compensation Techniques : Control Systems
Controller Components – Part 1 Objective Questions
Control of the Effects of Disturbance Signals by Use of Feedback
Mass Spectrometer Questions & Answers
Permit to Work System Online Test
Analytical Measurement Multiple Choice Questions
Time Domain Analysis
Necessary Conditions for Stability & Non-Linear Systems
Concept of Stability in Control Systems
Time Response of Second Order Systems – I
Digital Circuits Questions & Answers
Time of Flight Mass Spectrometer
Liquid Chromatography Questions & Answers
Digital Control Systems
The inverse z-transform & Response of Linear Discrete Systems
Top 100 Control Systems Objective Questions & Answers
Signal Flow Graphs Objective Questions
Electron Spin Resonance Questions & Answers
Instrumentation of ESR Spectrometer
Advances in Control System
Fuzzy Logic Control
Dissolved Oxygen Analyzer Questions and Answers
Stability in Frequency Domain
Nyquist Stability Criterion
Innovative Segment Orifice
Pitot-tube Replaced with Innovative Segment Orifice Plate
Fieldbus Control Loop
Foundation Fieldbus Communication Management
PLC Digital Inputs
PLC Digital Input and Digital Output Modules
PID Loop Tuning
PID Controller Loop Tuning Questions and Answers – Part 1
In this article, you will learn the configuration of PlantPAx library in factory talk studio of Rockwell Automation.
Configuration of PlantPAx Library in Factory Talk Studio
Performance of Systems Objective Questions
Performance of Control Systems Objective Questions
Ziegler-Nichols closed-loop Tuning
Ziegler-Nichols Closed-Loop Method (Ultimate Gain)
