Reading: Simple High Level Indicator Circuit
Inst Tools > Blog > Practical Questions > Simple High Level Indicator Circuit
A potable water storage tank requires a high level alarm to warn operations personnel. Design a simple indicator circuit.
Last updated: March 5, 2021 11:59 am
Practical Questions
1 Min Read
A potable (drinking) water storage tank requires a high-level alarm to warn operations personnel of impending overflow conditions.
A high-level switch is on order, but until this switch arrives for installation, you are asked to devise a very simple yet effective high-level indicator device that will function in the interim.
Explain how you would build such a device.
Bonus points for devising a method that uses very simple electronics parts (easily found in a electronics shop).
Since the process liquid is potable water, it is mildly conductive to electricity.
Virtually any high-level alarm circuit built around one or two electrodes located at the high-water level will suffice.
Here is a sample idea:
We can also use a simple transistor for controlling the relay based on the input voltage from the probe.
Do you have any other ideas? Share with us through the below comments section.
  • PLC based Drink Dispenser System
  • How to Configure an Alarm in InTouch SCADA?
  • Magnetic Level Indicators Working Animation
  • Analog Indicators Objective Questions
  • Investigate High Level Alarm of Distillation Process
Credits: Tony R. Kuphaldt
Oil and Air Pressure Actuated Lifts Questions
Determine the Temperature of 3 Wire RTD
Pneumatic Force Balance Instrument
pH Monitoring System Triggers an Alarm
Identify Two Pressure Switches Logic
Questions on Dip Tube Type Level System
Draw Limit Switch Symbol ?
Loop Powered Pressure Transmitter
Which Tube has most Hydrostatic Pressure?
Liquid Level Measurement using Pressure Transmitter Questions
Calculate PSV Lift Pressure
reactor vessel
Dry Leg
Calculate 0%, 50%, and 100% Calibration Points for ΔP transmitter
three-phase motor control circuits
How Overload Heaters used to Automatically Shut the Motor OFF ?
Alternative Vessel Level Indication
What is the Simple Alternative Vessel Level Indication?
Strain Gauge Bridge Circuit
Something is Wrong with Strain Gauge Bridge Circuit
Manometer Measures Differential Pressure
How Manometer Measures Differential Pressure for Different Fluids?
Programmable Logic Controller (PLC) Questions and Answers – 3
Pneumatic Moment-balance Differential Pressure Transmitter
Cybersecurity Projects for Engineering Students
What is RS Linx - Types of Softwares in Rockwell Automation
What is RS Linx? Types of Software in Rockwell Automation
Cable Shielding - Purpose, Selection, Grounding
Cable Shielding – Purpose, Selection, Grounding
Wellhead Control Panel
Basics of Wellhead Control Panel (WHCP)
Gate Array Logic using PLC
PLC Program to Simulate Gate Array Logic
Compile Project in Tia Portal
Communication between Wincc and Tia Portal
PLC Questions - 1
Sketch a Ladder Diagram for PLC to Energize the Lamp
