Reading: Shutter Door Control using Motor and Limit Switches
Inst Tools > Blog > Electrical Basics > Shutter Door Control using Motor and Limit Switches
 In this article, we are going to discuss about shutter door control using induction motor and limit switches.
Last updated: September 19, 2024 3:24 pm
K Mugunthan
Electrical Basics PLC Tutorials
6 Min Read
Shutter DoorComponents Used3 Pole Miniature Circuit Breaker3 Pole ContactorsStart & Stop ButtonsLimit SwitchesInduction MotorPower Circuit DiagramControl Circuit DiagramWorking PrincipleConclusion
Shutter Door
Shutters are common type of doors used in all types of areas like residential, commercial, and industrial purposes. They are nothing but doors which have big openings for material movements and coverages. Shutters are opened or controlled by many methods like manually, mechanically, and electrically in industries.
Now, we are going to discuss about the controlling of shutters using electrical motors. Commonly, in industries, this method is only because there will be more movement of material supplies and it will be difficult if we follow manual or mechanical methods.
The electrical method was easy to control and saved more time than others.
Components Used
  • 3 pole Miniature Circuit Breaker
  • 3 Pole Contactors
  • Start & Stop Buttons
  • Limit switches
  • Induction Motors
Miniature Circuit Breaker commonly known as MCB is used as the protective element for the system because it prevents the system from overcurrent and over voltage which will damage the actuating elements and other parts.
3 Pole Contactors
Contactors are the control elements that switch the supply to the actuating element from the control switches. In this, we used two contactors for forward and reverse control i.e., for Shutter up and down movements.
Start and Stop buttons are used to initiate and pause the system and the Start button here is  Up and Down buttons are used for control the up and down movement of the shutters.
Limit Switches
Limit switches are used to sense the end position on the system, here Up and Down limit switches are used to sense the end position on the top side and bottom side. Once the part touches the limit switches, the system will stop and it will not move beyond that.
Induction Motor
A three-phase motor is used to control the shutter movement Up and Down based on the control input.
Door Power Circuit Diagram
Door Control Circuit Diagram
Working Principle
A three-Phase supply of 415 V is given to the power circuit and a Single-Phase supply of 240 V is given to the control circuit.
The power circuit consists of an MCB, Contactors, and a motor. The control circuit consists of Pushbuttons, limit switches, and contactor coils.
Shutter Door Control using Induction Motor and Limit Switches
In the power circuit, the MCB is powered ON and the supply goes to the contactor and in the control circuit, the Shutter is on the top side so it makes contact with the Limit switch 1 (UP).
Then the Down button in the control circuit is pressed, which makes the  Contactor 1 coil energize which makes the Contactor 1 activate, So the motor starts to rotate in a clockwise rotation. This means the shutter moves from top to bottom.
Once the shutter is moved from the top position, the limit switch 1 (UP) will get disconnected.
Limit Switch Shutter Motor
Once the shutter starts to move downwards, it will reach the endpoint at the down point and it will engage the limit switch 2 (DOWN) which will make the motor to stop rotating.
Now the shutter is on fully downwards, practically now it is in close position.
Electric roller shutter motor with limit switch
If we want to open the shutter, then the Up button in the control circuit is pressed. Since it is engaged with limit switch 2 (DOWN), it makes the Contactor 2 coil energize which makes the Contactor 2 activate.
So the motor starts to rotate this time in a counter-clockwise direction as we have reversed the two phases in the power circuit.
Rolling Shutter Motor
Now, the shutter moves upwards and at the end, it will engage with Limit switch 1 (UP) and cuts the connection which makes the motor rotation to stop.
Garage Door Roller Shutter
Likewise, continuously we can control the Shutter movement with direction control of the motors with the help of limit switches and push buttons. If the stop push button is pressed all the function will be turned off instantly.
Conclusion
This is a typical control used for Shutter door movement in many areas of work. Since it has an easy mode of operation anyone can operate it in a safe manner and its servicing is also very easy. Because of its easy connection and control, it is one of the efficient and easy ways to control the shutter door.
  • What is an Electrical Conduit?
  • Single Core and Multi-Core Cables
  • Difference Between HV and LV Cables
  • Types of Cables in Industrial Automation
  • Flame Resistant and Retardant Cables
Peripheral Inputs and Outputs in Siemens PLC
Difference between Timer and Counter – PLC Basics
PLC Program for Traffic Light Sequence using Functional Blocks
Electrical Ladder Diagram Control using Timers Example
Example of Controlling the PLC Output using Push Buttons
Function Block (FB) for Motor Control Logic
Global Acknowledgment Instruction in Safety PLC
Types of CPU Communication Ports in Siemens PLC
Basic Concepts of the Safety Relay
PLC Programming Example for Motor Forward and Reverse Control
Safety Tips When Working With Electricity
How CPU Execute Program in Siemens PLC?
SFC Language in PLC Programming
Open Platform Communication (OPC)
Applications of Electrical Conduit System
What is an Electrical Conduit? – Types – How to Choose?
Masking in PLC
What is Masking in PLC?
T-Junction Traffic Control System
T-Junction Traffic Control System – PLC Programming
FBD Logic
Programmable Logic Controller Boiler Logic
PLC Ladder Logic for Start-up Control of Boilers
Programmable Logic Controller (PLC) PLC Maintenance Check Points
Programmable Logic Controller Maintenance Check Points
Pressure and Instrumentation MCQ - Questions & Answers
Pressure and Instrumentation MCQ – Questions & Answers
measure the temperature of RTD
Measure the Temperature of the RTD
Time Division Multiplexing Objective Questions
PID Controllers with output high select Logic
PID Controllers with Output High Select Logic
VLSI Projects for Engineering Students
700+ VLSI Projects for Engineering Students
Rack Type PLC
PLC Input Output Modules
Why is 24 Volts Commonly used in PLC Systems?
hand-crank megger photo
What is Megger Test?
