Reading: Self Actuated Pressure Control Valve Functional Testing
Inst Tools > Blog > Calibration > Self Actuated Pressure Control Valve Functional Testing
Last updated: April 29, 2019 10:12 am
Calibration Control Valves
2 Min Read
SELF ACTUATED PRESSURE CONTROL VALVE FUNCTIONAL TESTING
1) Pressure Reducing MethodTypical Test Set-upFunctional Testing Procedure2) Back Pressure Regulator MethodTypical Test Set-upFunctional Testing Procedure
Test Equipment Required :-
  1. Regulator
  2. Test Gauge
Typical Test Set-up
a. Check instrument data, check for pressure requirement.
b. Check vendor’s specification sheet or instrument nameplate maximum allowable pressure.
c. Hook-up instrument as typical test set-up.
d. Open Valve A, note down pressure indication of the test gauge B as the set pressure.
e. If the set pressure is not as per specification carry out as follows:
  • Remove the cover of the set point adjustment screw
  • Adjust the set point screw until the test gauge indicates the desired pressure.
f. Records all results in Instrument Calibration Check sheets.
  1. Regulator
  2. Test Gauge
Typical Test Set-up
Back pressure Regulator Pressure Control Valve Testing
Why Restriction Orifice is some distance from Blowdown valve ?
Smart Transmitter Calibration Tutorial Part 1
How are HART instruments Calibrated?
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Basics of Control Valve Sizing
What is a Float Control Valve? Types, Advantages, Disadvantages
Motor Operated Valve Problems and Troubleshooting
Control Valves Pre-Commissioning Checklist
Valves Pressure Loss – Questions and Answers
What is Instrument Air Manifold ?
What is a Pilot Valve? When do we use a Pilot Valve?
Electronic Valve positioners
Control Valve Stroke Test Procedure
Globe Valve Seat and Disk
Pneumatic Actuators
Self-Actuated Valves, Pneumatic & Hydraulic Actuators
Closed tank DP Level Transmitter with wet leg elevation zero remote mount Calibration
Difference between Accuracy, Tolerance, Uncertainty, and Error
Air Lock Relay Working Principle
Control Valve Air Lock Relay Working Principle
What is Directional Control Valve (DCV)?
Pressure Gauge Calibration according to Standard DKD-R-6-1
Objective Questions on Valves
Plug Valve Parts
What is Plug Valve ?
double-pumps unit unloading valves
What is an Unloading Valve? – Types, Principle
What is a Multi-Core Cable
Difference Between Single Core and Multi-Core Cables
Transistor-cut-off-saturation-active-regions
Transistor Cut off, Saturation & Active Regions
simple latching motor control circuit
Motor Control Circuit Wiring
What is a Voltage Reference
What is a Voltage Reference? – Electronic Components
Calibration Interview Questions and Answers
Single-beam non-dispersive analyzer
Single-beam Non-dispersive Analyzer
PLC Programming Software
