Instrumentation engineering root cause analysis of Safety Liquid ammonia Disconnect threatens Large Quantities NH3 Vapor Spill.
| Category: | Instrumentation |
| Equipment Type: | Instruments |
Safety Liquid Ammonia Disconnect threatens NH3 Vapor Spill
Problem: The port authorities while inspecting the liquid ammonia (LA) to issue permits for its routine operation, identified a flaw and suggested a remedy too:
Read Previous Article: Ammonia Ball Valve Failure
The ship tank’s NH3 inlet nozzle to which the liquid ammonia (LA) clamps has a block valve. However, realizing a LA disconnect and closing the large block valve takes few minutes. But the large quantity of NH3 spill makes approaching the valve impossible.
In addition, it requires all in the area going away to escape the pungent ammonia odors. All these affect port operations seriously.
Hence the port authorities insisted on the plant crew bolting check valve to the ship nozzle valve. After LA clamping they open the block valve. This way in case of a LA unclamp the check valve prevents NH3 spill and thus the associated problems as above.
This was indeed an effective excellent safety precaution. The plant readily accepted the suggestion and implemented it and enjoys the benefits of every ship loading.
Author: S. Raghava Chari
- Pressure Switch Screwed Cover
- Too Low-Temperature Readings
- Damaged Magnetic Flow Tube
- Thermowell Shank to Flange Leaks
