Reading: Role of Flow Meters in a Laboratory
Inst Tools > Blog > Guest Articles > Role of Flow Meters in a Laboratory
Last updated: December 23, 2017 6:24 am
Guest Articles
The Role of Flow Meters in a Laboratory
Flow meters are devices used to measure the flow rate or quantity of a gas or liquid moving through a pipe. Flow measurement applications and devices are diverse and vary depending on the industry. Accordingly, each flow meter has its own set of standards and engineering requirements depending on the basis of its application.
In a laboratory environment, flow meter products and calibration services are tailored to an industry which requires precision materials and equipment given the nature of a laboratory environment. And flow meters play an important role in many of the working projects that take place in this setting.
 Types of Flow Meters Used in a Laboratory Environment
Turbine flow meters with signal conditioner and converters are calibrated to measure the flow of air, methane gas and hydrogen gas. Like a standard turbine flow meter, a tangential turbine flow meter with customized carbon pivot bearings in weatherproof housing can also be calibrated to measure the flow of water and air. In a laboratory environment, as an example, this kind of capability can allow for the testing of different types of gasses for potential toxicity. Water and air can also be tested for potentially harmful pollutants.
Another example of a flow meter used in laboratory settings is a flow meter that possesses RF pick-ups, which is calibrated to measure the flow of nitrogen gas. One of several benefits of this application is that it can assist in addressing threats in the form of poisonous gas attacks which remain a continuous threat to our national security.
Additional Flow Meters and Flow Meter Equipment
Variable Area Flowmeters (Rotameters) are available in a wide range of liquid and gas flow rates. They contain horizontal end fittings and can rotate in 90-degree increments. They also have clean-out ports, panel or in-line mounting hardware, direct reading scales that are engraved for each application, and heavy gauge steel frames with corrosion resistant epoxy paint among other features.
Flow computers, such as an instrument verification set, are portable instrument and diagnostic measuring tools which can, among other applications, verify the flow, pressure and temperature of hydraulic systems and instruments. They are an effective supplement to flow meters and can be beneficial in the maintenance and monitoring of systems operations.
Batch Controllers display rate, batch size and batch or grand total. They contain magnetic pick-up inputs, analog outputs and five-digit scaling factors, in addition to security lockouts and serial communication. They also contain Second B relay which is programmable for output at a pre-warn or selected batch/grand total. Like flow computers, they are a useful component in ensuring that each of the elements involved in an operation are performing at proper capacity.
Flow Meter Repairs
When working in a laboratory environment, whether in an academic, research-based or other capacity, it is important to work with a company which specializes in the production and proper maintenance of flow meter equipment. Working with a company that has an established track record in this area can prove beneficial in the event of a need for recalibration or repairs to existing equipment. Such companies maintain and foster their relationships with their clients and often offer services for the professional repair and replacement of equipment in the event the situation arises.
PLC Program for Conditional Control Logic
cat5e Plenum Cable History, Advantages and Disadvantages
Best Preparation Tool You Can Get Online for Microsoft MS-200
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
  • praveen says:
    June 2, 2020 at 12:16 pm
    i need know how hydro testing is done in road tankers which carry lpg in it
Why You Need FDA Process Validation and How to Do It Right ?
Cisco CCNP R&S : All Actual Information About This Certification
Why we Require Dual SOV on a Control Valve?
Nuclear Level Detectors Cascade or Master/Slave concept
Circular Chart Recorder Calibration Procedure
3 Phase Motor Control using PLC Ladder Logic
Internal Powered Modems
conductivity transmitter
Conductivity Transmitter Calibration Procedure
Displacer Level Transmitter weight calibration
Displacer Level Transmitter Dry Calibration with Weights
5 Tips to Pass CFSE Exam
Instrumentation Colleges in United States
Colleges to Study Instrumentation Engineering in United States
Two Out of Three Logic
Alarm and Trip Systems
Control Valve Actuator Parts
Reversing Control Valve Actuator Fail Safe Mode
Abbreviations of Pressure, Temperature & Flow
Accelerometer Vibration Probe
Accelerometer Vibration Probe Principle
How a PLC communicates with Transmitters
How PLC Reads the Data from Field Transmitters
Probe Thermometer
What is a Probe Thermometer? How to Calibrate and Use it?
Induction Motor Torque
AC Induction Motor Slip
PID-Controller-Simulator-graph
PID Controller Tunning Parameters Simulator
Displacer Operated Level Switch Working Principle
Displacer Level Switch Working Principle
4-20mA Current Loop
Basics of 4-20mA Current Loop
Harmonic Reduction Objective Questions
Introduction of Urea Bagging machine
Introduction to Urea Bagging Machine
