Reading: Retentive ON Delay Timer using PLC
Inst Tools > Blog > PLC Tutorials > Retentive ON Delay Timer using PLC
Last updated: March 4, 2021 3:37 pm
2 Comments
3 Min Read
This article discusses about Retentive ON Delay Timer instruction and working principle using Allen Bradley Programmable Logic Controller (PLC) Ladder Logic.
Retentive ON delay timerProgram Description:Retentive ON delay timer using PLCConclusion
In the above Retentive ON Delay Timer, there are totally four parameter,
TIMER: T4:0 – Timer File name (Timer T4:0, T4:1, T4:2…)
TIMER BASE – How the time need to count, in Seconds, Milli Seconds…
PRESET – Limit value of Timer-Up to how much it should count
ACCUMULATOR – Running Value of timer when it is in ON condition.
Retentive ON delay timer is to delaying the ON time, if input goes off in between, it will resumes the accumulator value and input turns ON, it will start running for the resumed value.
Example-VLC video player plays video from the resumed placed if we closed and open the player again.
Retentive Timer Logic
Retentive ON delay timer using PLC Logic
RUNG 0000:
Start and Stop Switch is to turn ON/OFF the timer.
RUNG 0001:
When start switch is pressed, Timer Enable bit (T4:0/EN) is turned ON to show the status of TIMER ON/OFF condition
RUNG 0002 :
When start switch is pressed, along with the timer enable bit timer timing bit also turned ON to show the status of timer’s accumulator (T4:0/ACC)value is currently in running state.
RUNG 0003:
When start switch is pressed, timer starts running from zero to preset valve, timer’s done bit is turned ON when accumulator value reached preset value.
Notes: Reset is done automatically in this program to run the program continuously.
Conclusion
We can use this example program to understand the working of Retentive ON delay timer function in Allen Bradley PLC.
Author : Hema Sundaresan
PLC Sequential Motor Control
PLC Problems Troubleshooting
Motor Trip Logic using PLC
PLC Counter Instructions
Blinking Lamp on 5s in PLC
PLC Practice Questions
Parking Garage Indicator: PLC Automation System
Drilling Process using PLC Program
PLC Ladder Logic for Start-up Control of Boilers
PLC Logic Functions
PLC Math instructions
2 Comments
  • S.b says:
    November 6, 2020 at 7:31 pm
    Can u say me the ans of explain operation of retentive on delay timer function using timming diagram
    • Sar Det says:
      July 16, 2021 at 5:13 am
      Explain PLC S7 Siemens
Top Free PLC Software
Split Range Control Application using PLC Ladder Logic
PLC Electric Motor Interlocks
HMI Handbook
What is Human Machine Interface (HMI) ?
Industrial Automation Cold and Hot Standby
PLC Programming Example on Bottle Line Control
Types of PLC Memory
Types of PLC Memory
How to use Scale and Normalize Instructions in PLC
How to Delay a Sensor Signal in PLC?
Micro 870 Rockwell PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
Siemens CPU MP Port
Siemens S7-300 CPU Suffix Explanation
Wonderware Recipe Manager Plus
What is Recipe Management in SCADA?
types of Orifice Plates
Types of Orifice Plates & Orifice Plate Tappings
Electrical & Instrumentation QA QC Interview Questions
100 Electrical & Instrumentation QA QC Interview Questions
Functional block diagram for analog alarms
PLC Logic for Analog Alarms using Functional Block Diagram
PID Controller Tunning Manually
PID Controller Parameters Tuning Manually
Open-Tank-DP-Level-Transmitter-with-Zero-Suppression-Calibration
DP Level Transmitter with Zero Suppression Calibration
PCB Making Machine
Beyond FR-4: Exploring Novel Materials for PCB Fabrication
Zener Diode Voltage Regulator Operation
Impulse Steam Trap
Impulse Steam Trap
