Reading: How to Reduce Relay Noise in PLC Systems?
Inst Tools > Blog > PLC Tutorials > How to Reduce Relay Noise in PLC Systems?
Today we are going to discuss about Relay Noise reduction method for a PLC system. we observe more noise is generating by relay output switching.
Last updated: November 2, 2023 3:24 pm
1 Min Read
Today we are going to discuss about Relay Noise reduction method. Sometimes we observe more noise is generated by relay output switching.
How to Reduce Relay Noise in PLC SystemsCountermeasure Example
In such case, a Noise filter must be connected to the load side or other appropriate countermeasures must be provided external to the PLC.
Countermeasures are not required if the frequency of load switching for the whole system with the PLC included is less than 5 times per minute means required after more than 5 times per minute.
When switching an inductive load,connect an surge protector, diodes,etc in parallel with the load or contact as shown below:
When switching a load with a high inrush current such as an incandescent lamp, Suppress the inrush current as shown below:
Relay Noise in PLC
  • Solid-state Relays
  • DCS versus PLC Architecture
  • Phototransistor Circuit Example
  • Parallel Short Circuit Faults
SCADA Systems
PLC Latching Function
How to Create New Project in Studio 5000?
PLC SCADA Engineers Interview Questions and Answers
Flip-Flop PLC Programming: Lights with Adjustable Timers
FB Block in Siemens PLC Programming
Timer during Motor Direction Change PLC Program
Playground Swing Logic Exercise Program in PLC
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
100 Electrical Circuit Breaker Quiz
Siemens PLC Tia Portal – OB100 Start-up Organization Block
Programmable Logic Controller (PLC) Scan Time – Types, Theory
SCADA backup too has been configured
FactoryTalk Studio and SQL Server for Data Logging
Top Free PLC Software
Surge Protection Device
Types of Interrupts Organization Blocks in Tia Portal
Types of Interrupt OB in Siemens Tia Portal
What is Fail-safe in Siemens PLC?
Ladder Logic Programming Examples
Electronic Force Balance Pressure Transmitter
Electric Circuits Objective Questions – Set 8
Hydraulic Actuator
Types of Valve Actuators
Technology is Shaping the Future of Education
How Technology is Shaping the Future of Education?
Magnetic Flowmeter vs. Turbine Flowmeter
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
Landline Telemetry Objective Questions
Needle Valve Body Design
What is Needle Valve ?
Sensors and Transducers Objective Questions
